[菜农助学交流] DS18B20实验
 楼主| ltbytyn 发表于 2011-11-29 15:10 | 显示全部楼层 |阅读模式
#include "Smpl_Drv_DS1820.h"
volatile uint16_t value = 0 ;
volatile uint8_t mark;           //温度正负标志
volatile uint8_t IsStart = FALSE;
volatile uint8_t Receive_Data = 0;
void UART_INT_HANDLE(uint32_t u32IntStatus)
  uint8_t bInChar[1]={0xFF};
if(u32IntStatus & DRVUART_RDAINT)
  /* Get all the input characters */
  while(UART0->ISR.RDA_IF==1)
   /* Get the character from UART Buffer */
   DrvUART_Read(UART_PORT0,bInChar,1);
   if (IsStart!=TRUE)
    IsStart = TRUE;
    Receive_Data = bInChar[0];
void Init_Uart(void)
STR_UART_T param;
声明 UART设置的结构体 位于DRVUART.H
结构体如下
typedef struct DRVUART_STRUCT
  uint32_t            u32BaudRate;
  E_DATABITS_SETTINS  u8cDataBits;
  E_STOPBITS_SETTINS  u8cStopBits;
  E_PARITY_SETTINS  u8cParity;
  E_FIFO_SETTINGS     u8cRxTriggerLevel;
  uint8_t             u8TimeOut ;
      }STR_UART_T;
DrvSYS_SelectIPClockSource(E_SYS_UART_CLKSRC,0);      //使能UART时钟
//SYSCLK->CLKSEL1.UART_S = 0;  //UART时钟源选择. 00 =外部12MHz 晶振 01 = PLL 1x =内部 22MHz 振荡器
DrvGPIO_InitFunction(E_FUNC_UART0);          //GPB_MFP0-1-2-3置位 GPIO使能UART功能
//outpw(&SYS->GPBMFP, inpw(&SYS->GPBMFP) | (0xF<<0));
param.u32BaudRate        = 115200;       //  波特率
param.u8cDataBits        = DRVUART_DATABITS_8;    //  数据位
param.u8cStopBits        = DRVUART_STOPBITS_1;    //  停止位
param.u8cParity          = DRVUART_PARITY_NONE;    //  校验位
param.u8cRxTriggerLevel  = DRVUART_FIFO_1BYTES;    //  FIFO存储深度 1 字节
param.u8TimeOut          = 0;        //  FIFO超时设定
/* Set UART Configuration */
  if(DrvUART_Open(UART_PORT0,¶m) != E_SUCCESS)   //  串口开启、结构体整体赋值
  printf("UART0 open failed\n");
/* u32Port -[in] UART Channel:  UART_PORT0 / UART_PORT1 /UART_PORT2 */
/* sParam  -[in] the struct parameter to configure UART    */
/* Enable Interrupt and install the call back function */
DrvUART_EnableInt(UART_PORT0, DRVUART_RDAINT,UART_INT_HANDLE);
/*u32Port     -[in] UART Channel:  UART_PORT0 / UART_PORT1 / UART_PORT2                   */
/*u32InterruptFlag -[in] DRVUART_LININT/DRVUART_WAKEUPINT/DRVUART_BUFERRINT/DRVUART_RLSINT     */
/*          DRVUART_MOSINT/DRVUART_THREINT/DRVUART_RDAINT/DRVUART_TOUTINT   */
/*pfncallback      -[in] A function pointer for callback function                              */
int main (void)
  Set_System();
  Init_Uart();
printf("======温度实验=====\n");
while(1)
  value = read_temp();
   printf("当前温度: %d.%d℃",value/10,value%10);
  delay_ms(2000);
有详细注释。
hotpower 发表于 2011-11-29 15:41 | 显示全部楼层
最好贴出主代码,否则不一定每个人都要下载,看看其它网友的帖子。
nxparm_ad 发表于 2014-5-7 08:33 | 显示全部楼层
标记下,以后需要再来看x1
Dick00 发表于 2014-5-7 08:48 | 显示全部楼层
感觉18B20的时序好难写啊,参考下。。。
Dick00 发表于 2014-5-7 09:03 | 显示全部楼层
再冒昧的问一句,18B20的数据口设置输入输出的时候是选择的那种模式?推挽输入输出?
缥缈九哥 发表于 2014-8-9 22:25 | 显示全部楼层
顶起
