[DemoCode下载] NuTiny-EVB-M051例子来了
 楼主| gaoyang9992006 发表于 2020-2-18 13:42 | 显示全部楼层 |阅读模式
NuTiny-EVB-M051.zip (1.33 MB, 下载次数: 23)
  1. /**************************************************************************//**
  2. * [url=home.php?mod=space&uid=288409]@file[/url]     main.c
  3. * [url=home.php?mod=space&uid=895143]@version[/url]  V3.00
  4. * $Revision: 4 $
  5. * $Date: 15/05/22 2:51p $
  6. * [url=home.php?mod=space&uid=247401]@brief[/url]    Show how to set GPIO pin mode and use pin data input/output control.
  7. *        基于NuTiny-EVB-M051开发板,LED在P3.6管脚,低电平点亮LED。
  8. * @note
  9. * Copyright (C) 2013 Nuvoton Technology Corp. All rights reserved.
  10. ******************************************************************************/
  11. #include <stdio.h>
  12. #include "M051Series.h"
  13. #define PLL_CLOCK           50000000
  14. void SYS_Init(void)
  15. {
  16.     /*---------------------------------------------------------------------------------------------------------*/
  17.     /* Init System Clock        */
  18.     /*---------------------------------------------------------------------------------------------------------*/
  19.     /* Enable Internal RC 22.1184MHz clock */
  20.     CLK_EnableXtalRC(CLK_PWRCON_OSC22M_EN_Msk);
  21.     /* Waiting for Internal RC clock ready */
  22.     CLK_WaitClockReady(CLK_CLKSTATUS_OSC22M_STB_Msk);
  23.     /* Switch HCLK clock source to Internal RC and HCLK source divide 1 */
  24.     CLK_SetHCLK(CLK_CLKSEL0_HCLK_S_HIRC, CLK_CLKDIV_HCLK(1));
  25.     /* Enable external XTAL 12MHz clock */
  26.     CLK_EnableXtalRC(CLK_PWRCON_XTL12M_EN_Msk);
  27.     /* Waiting for external XTAL clock ready */
  28.     CLK_WaitClockReady(CLK_CLKSTATUS_XTL12M_STB_Msk);
  29.     /* Set core clock as PLL_CLOCK from PLL */
  30.     CLK_SetCoreClock(PLL_CLOCK);
  31.     /* Enable UART module clock */
  32.     CLK_EnableModuleClock(UART0_MODULE);
  33.     /* Select UART module clock source */
  34.     CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART_S_PLL, CLK_CLKDIV_UART(1));
  35.     /*---------------------------------------------------------------------------------------------------------*/
  36.     /* Init I/O Multi-function        */
  37.     /*---------------------------------------------------------------------------------------------------------*/
  38.     /* Set P3 multi-function pins for UART0 RXD and TXD */
  39.     SYS->P3_MFP &= ~(SYS_MFP_P30_Msk | SYS_MFP_P31_Msk);
  40.     SYS->P3_MFP |= (SYS_MFP_P30_RXD0 | SYS_MFP_P31_TXD0);
  41. }
  42. void UART0_Init(void)
  43. {
  44.     /*---------------------------------------------------------------------------------------------------------*/
  45.     /* Init UART        */
  46.     /*---------------------------------------------------------------------------------------------------------*/
  47.     /* Reset UART0 */
  48.     SYS_ResetModule(UART0_RST);
  49.     /* Configure UART0 and set UART0 Baudrate */
  50.     UART_Open(UART0, 115200);
  51. }
  52. /*---------------------------------------------------------------------------------------------------------*/
  53. /* MAIN function        */
  54. /*---------------------------------------------------------------------------------------------------------*/
  55. int main(void)
  56. {
  57.     /* Unlock protected registers */
  58.     SYS_UnlockReg();
  59.     /* Init System, peripheral clock and multi-function I/O */
  60.     SYS_Init();
  61.     /* Lock protected registers */
  62.     SYS_LockReg();
  63.     /* Init UART0 for printf */
  64.     UART0_Init();
  65.     printf("\n\nCPU [url=home.php?mod=space&uid=72445]@[/url] %d Hz\n", SystemCoreClock);
  66.     printf("+-------------------------------------------------+\n");
  67.     printf("|    P3.6(Output) Sample Code     |\n");
  68.     printf("+-------------------------------------------------+\n\n");
  69.     /* Configure P3.6 as Output mode*/
  70.     GPIO_SetMode(P3, BIT6, GPIO_PMD_OUTPUT);
  71.         printf("GPIO P3.6(output mode)......");
  72.     /* Use Pin Data Input/Output Control to pull specified I/O or get I/O pin status */
  73.     P36 = 0;
  74.     while(1)
  75.                 {
  76.                         P36^=1;
  77.                         CLK_SysTickDelay(250000);
  78.                         CLK_SysTickDelay(250000);
  79.                 }
  80. }
  81. /*** (C) COPYRIGHT 2013 Nuvoton Technology Corp. ***/
 楼主| gaoyang9992006 发表于 2020-2-18 13:44 | 显示全部楼层
看你们找不到资料,我发现那个DVD光盘里也没有。
xuanhuanzi 发表于 2020-2-18 15:36 | 显示全部楼层
多谢大佬分享
xuanhuanzi 发表于 2020-2-18 15:37 | 显示全部楼层
原来这个板子只有一个LED可以编程啊
mintspring 发表于 2020-2-18 15:59 | 显示全部楼层
资料不错,有没有建立工程的步骤说明。
heisexingqisi 发表于 2020-2-18 20:09 | 显示全部楼层
多谢大佬的例子,学习学习。
huahuagg 发表于 2020-2-18 20:41 | 显示全部楼层
看了一下,时钟配置貌似所有例子都是差不多的,所有可以直接封装成函数,调用就行了。
jiekou001 发表于 2020-2-18 21:27 | 显示全部楼层
学习一下。
Harvard 发表于 2020-2-18 22:54 | 显示全部楼层
新唐bsp库里面不是都有么 ...
antusheng 发表于 2020-2-20 12:55 | 显示全部楼层
这比BSP里的好懂多了。
antusheng 发表于 2020-2-20 12:56 | 显示全部楼层
新唐bsp库里面不是都有么 ...
BSP里的太复杂,没这个好懂。
zhuomuniao110 发表于 2020-4-12 17:44 | 显示全部楼层
有人找这个,我推荐过去了。
zhuomuniao110 发表于 2020-4-12 18:02 | 显示全部楼层
例子不错。
598330983 发表于 2020-4-12 18:39 | 显示全部楼层
来看看。
antusheng 发表于 2020-4-12 22:22 | 显示全部楼层
这个比较简单,好理解。
2049
