CPU:RK3399
系统:Android 7.1
删除开机锁屏界面
diff --git a/frameworks/base/packages/SettingsProvider/res/values/defaults.xml b/frameworks/base/packages/SettingsProvider/res/values/defaults.xml
index f4cefc2..7734cfd 100644
--- a/frameworks/base/packages/SettingsProvider/res/values/defaults.xml
+++ b/frameworks/base/packages/SettingsProvider/res/values/defaults.xml
@@ -80,7 +80,7 @@
<string name="def_trusted_sound" translatable="false">/system/media/audio/ui/Trusted.ogg</string>
<string name="def_wireless_charging_started_sound" translatable="false">/system/media/audio/ui/WirelessChargingStarted.ogg</string>
- <bool name="def_lockscreen_disabled">false</bool>
+ <bool name="def_lockscreen_disabled">true</bool>
<bool name="def_device_provisioned">false</bool>
<integer name="def_dock_audio_media_enabled">1</integer>
