[MCU] PC机没有接收数据
 楼主| yszong 发表于 2020-3-1 16:04 | 显示全部楼层 |阅读模式
以下部分代码在28335中用RS232与PC机串口调试软件通讯正常,我作少许改动,移动28035中,用ADM483E芯片,作成485通讯,但是与PC机不能正常通讯,PC机不停向DSP发送数据,DSP可以接收到(但有时不数据不准确),但不能发送数据,即PC机没有接收到响应的数据。
dengdc 发表于 2020-3-1 16:08 | 显示全部楼层
代码呢
 楼主| yszong 发表于 2020-3-1 16:15 | 显示全部楼层
#include "DSP28x_Project.h"     // Device Headerfile and Examples Include File
unsigned int Sci_VarRx;
unsigned int Sci_VarTx;
int Send_Flag;
int SciaTx_Ready(void);
int SciaRx_Ready(void);
int Rx_flag;
int Tx_flag;
void Scia_init(void);
void main(void)
    Rx_flag=0;
    Tx_flag=0;
    Sci_VarRx = 0;
    Sci_VarTx = 0;
    Send_Flag = 0;
    InitSysCtrl();//LSPCLK=SYSCLKOUT/2=60MHZ/2=30MHZ
    InitSciaGpio();
EALLOW;
      GpioCtrlRegs.GPAPUD.bit.GPIO25 = 0;     //配置485-RTS使能上拉
      GpioCtrlRegs.GPAMUX2.bit.GPIO25 = 0;    //配置485-RTS的GPIO25为IO功能
      GpioCtrlRegs.GPADIR.bit.GPIO25 = 1;     //配置485-RTS为输出
      GpioDataRegs.GPADAT.bit.GPIO25 = 0;     //设置485-RTS默认输出为低电平
//控制ADM483E2、3脚电平(2、3脚已短路)
   EDIS;
    DINT;
IER = 0x0000;
IFR = 0x0000;
InitPieVectTable();
    Scia_init();
    EnableInterrupts();
     PieCtrlRegs.PIECTRL.bit.ENPIE = 1;   // Enable the PIE block
EINT;   // Enable Global interrupt INTM
ERTM; // Enable Global realtime interrupt DBGM
for(;;)
        SciaTx_Ready();
  if((Tx_flag == 1) && (Send_Flag == 1))
   switch(Sci_VarRx)
    case 48:Sci_VarTx=50;   //H
             break;
    case 49:Sci_VarTx=101;  //e
             break;
    case 50:Sci_VarTx=108;  //l
             break;
    case 51:Sci_VarTx=108;  //l
             break;
    case 52:Sci_VarTx=111;  //o
             break;
    default: Sci_VarTx=48;
   SciaRegs.SCITXBUF =Sci_VarTx;
   Send_Flag = 0;
  SciaRx_Ready();
  if(Rx_flag == 1)
   Sci_VarRx = SciaRegs.SCIRXBUF.all;
   Send_Flag = 1;
void Scia_init()
SciaRegs.SCICCR.all =0x0007;   // 设置通信控制寄存器
                                   // 0x0007 = 0000 0111
                                   //STOP BITS = 0(1 个停止位)
                                   //EVEN/ODD PARITY = 0(奇校验)
                                   //PARITY ENABLE = 0(奇偶校验禁用)
                                   //LOOP BACK ENA = 0(自测试模式禁用)
                                   //ADDR/IDLE MODE = 0(选择空闲线模式协议)
                                   //SCI CHAR2-0 = 7(选择8位SCI字符长度)
    SciaRegs.SCICTL1.all =0x0003;  // 设置SCI控制寄存器1
                                   // 0x0007 = 0000 0011
                                   //RX ERR INT ENA = 0(接收错误中断禁用)
                                   //SW RESET = 0(向此位写入0将初始化SCI状态机和操作标志(寄存器SCICTL2和SCIRXST)为复位条件)
                                   //TXWAKE = 0(发送特征未选择)
                                   //SLEEP = 1(休眠模式使能)
                                   //TXENA = 1(发送器使能)
                                   //RXENA = 1(接收器使能)
SciaRegs.SCICTL2.all =0x0003;//设置控制寄存器2
                              //0x0003 = 0000 0011
                              //TXRDY = 0(SCITXBUF已满)
                              //TX EMPTY = 0(发送器缓冲寄存器和移位寄存器均为空)
                              //RX/BK INT ENA = 1(使能RXRDY/BRKDT中断)
                              //TX INT ENA = 1(使能TXRDY中断)
SciaRegs.SCICTL2.bit.TXINTENA =1; //使能TXRDY中断
SciaRegs.SCICTL2.bit.RXBKINTENA =1; //使能RXRDY/BRKDT中断
    SciaRegs.SCIHBAUD    =0x0000;  //
    SciaRegs.SCILBAUD    =0x00C2;  //波特率为LSPCLK/[(194+1)*8]=30M/(195*8)=19200(波特率取19200)
//ScibRegs.SCICCR.bit.LOOPBKENA =1; // 自测试模式使能
SciaRegs.SCICTL1.all =0x0023;     // 0x0023 = 0010 0011
                                //SW RESET = 1(系统复位后,向此位写入1将重新使能SCI)
int SciaRx_Ready()
GpioDataRegs.GPADAT.bit.GPIO25 = 0; //低电平
DELAY_US(1000);
if(SciaRegs.SCIRXST.bit.RXRDY == 1)
/*数据从RXSHF接收移位器移入缓冲寄存器(SCIRXBUF)时,SIC接收器就绪标志位(RXRDY)置1,表明一个新的字符已经接收,*/
   Rx_flag = 1;
else
   Rx_flag=0;
return(Rx_flag);
GpioDataRegs.GPADAT.bit.GPIO25 = 1; //高电平
DELAY_US(1000);
if(SciaRegs.SCICTL2.bit.TXRDY == 1)
/*当SCI发送缓冲寄存器(SCITXBUF)中的数据传送到TXSHF寄存器时,则发送就绪,标志位TXRDY被置1*/
  Tx_flag=1;
else
  Tx_flag=0;
return(Tx_flag);
// No more.
 楼主| yszong 发表于 2020-3-1 16:19 | 显示全部楼层
此程序功能为:当PC机串口调试软件向DSP发送0时,应收到返回信息H;向DSP发送1时,应收到返回信息e
liliang9554 发表于 2020-3-1 16:22 | 显示全部楼层
没遇到过,帮顶
没遇到过,帮顶
liliang9554 发表于 2020-3-1 16:25 | 显示全部楼层
没遇到过,帮顶
 楼主| yszong 发表于 2020-3-1 16:30 | 显示全部楼层
现在通讯可以正常接收和响应了,但是接收的数据每不稳定,比如。PC发送0时,DSP接收的数据应该是48,有时是正确的,有时其它的数据。为什么?
jiajs 发表于 2020-3-1 16:33 | 显示全部楼层
你可以使用串口调试工具看看你的缓冲区的数据
wyjie 发表于 2020-3-1 16:39 | 显示全部楼层
使用串口调试工具试一下   看看工作是否正常   如果还不正常   建议先看看硬件电路   确保硬件电路正常情况下   在仔细阅读代码查错
heweibig 发表于 2020-3-1 16:42 | 显示全部楼层
楼主,请问你用的是什么串口调试工具啊
 楼主| yszong 发表于 2020-3-1 16:45 | 显示全部楼层
现在已解决了,我把程序的流程重新改变了一下。
ousj 发表于 2020-3-1 16:49 | 显示全部楼层
DSP发送的数据不能接受吗
kangzj 发表于 2020-3-1 16:52 | 显示全部楼层
测试PC端是否有信号
yufe 发表于 2020-3-1 17:01 | 显示全部楼层
你的硬件电路怎么设计的
huwr 发表于 2020-3-1 17:04 | 显示全部楼层
添加一个上拉电阻
dingy 发表于 2020-3-1 17:07 | 显示全部楼层
你释放了控制信号?
liuzaiy 发表于 2020-3-1 17:10 | 显示全部楼层
不能移植232的代码
kangzj 发表于 2020-3-1 17:16 | 显示全部楼层
把你的代码上传看看。
yufe 发表于 2020-3-1 17:20 | 显示全部楼层
就是没有CTRL信号吧。
