PWM Control Controller for 5V/3A,5V/3.1-5A solution 10.AX3304/A-PWM Control Controller
AX3304/A-PWM Control Controller DataSheet AX3304(100Khz/300Khz) High Efficiency solution For 5V/3A 5V/3.1A solution
Vin : 8V~38V
* Freq=100Khz/300Khz
* Build in Line compensate +OCP+OVP function
* Supply CC / CV for Li-on battery charger mode
* EMI & TMC Approval available
FEATURES
- Input voltage:8V to 38V
- Duty ratio:0% to 100% PWM control
- Oscillation frequency:100K/300KHz
- Thermal Shutdown function.
- Short Circuit Protect (SCP).
- External SW P-channel MOS.
- External OVP setting function.
- Current mode non-synchronous PWM converter
- External current limit setting.
- Under voltage Lockout.
- SOP-8L Pb-Free package.
