[MCU] 两个一起测的话要怎么设置?
 楼主| zhaoxqi 发表于 2020-4-4 16:38 | 显示全部楼层 |阅读模式
msp430g2553,有ADC10,要侧A7和A6的电压,然后分别读出值,单独测都行,两个一起测的话要怎么设置?
wuhany 发表于 2020-4-4 16:42 | 显示全部楼层
可将ADC10设置为Single Sequence 模式
zhenykun 发表于 2020-4-4 16:44 | 显示全部楼层
可将ADC10设置为Single Sequence 模式.
如下为对A2,A1,A0连续读取的例子,可参考修改.
void main(void)
   WDTCTL = WDTPW + WDTHOLD;                 // Stop WDT
   ADC10CTL1 = INCH_3 + CONSEQ_1;            // A3/A2/A1, single sequence
   ADC10CTL0 = ADC10SHT_2 + MSC + ADC10ON + ADC10IE;
   ADC10DTC1 = 0x03;                         // 3 conversions
   ADC10AE0 |= 0x0E;                         // P1.3,2,1 ADC10 option select
   P1DIR |= 0x01;                            // Set P1.0 output
  for (;;)
     ADC10CTL0 &= ~ENC;
     while (ADC10CTL1 & BUSY);               // Wait if ADC10 core is active
     ADC10SA = 0x200;                        // Data buffer start
     P1OUT |= 0x01;                          // P1.0 = 1
     ADC10CTL0 |= ENC + ADC10SC;             // Sampling and conversion start
     __bis_SR_register(CPUOFF + GIE);        // LPM0, ADC10_ISR will force exit
     P1OUT &= ~0x01;                         // P1.0 = 0
// ADC10 interrupt service routine
#pragma vector=ADC10_VECTOR
__interrupt void ADC10_ISR(void)
   __bic_SR_register_on_exit(CPUOFF);        // Clear CPUOFF bit from 0(SR)
zhenykun 发表于 2020-4-4 16:48 | 显示全部楼层
jiahy 发表于 2020-4-4 16:51 | 显示全部楼层
轮询测试2个通道,从A6开始,A7结束
 楼主| zhaoxqi 发表于 2020-4-4 16:53 | 显示全部楼层
哦,知道了,多谢大家
