请问有人遇到STC8G1K08 20PIN AD采集错误的问题吗??
 楼主| gavin87 发表于 2020-4-17 16:29 | 显示全部楼层 |阅读模式
我的程序是从STC15W408AS里面移植过来的,里面应用了TIM0,1,2 ,PCA做8位PWM输出功能,用P1.2,P1.5做AD功能进行采集,发现AD5 有问题,AD2正常, 后把AD5变为AD3和AD4,发现也正常,变为AD6就出问题,请问有人遇到过相关问题的吗? 怎么解决问题的! 谢谢!
ayb_ice 发表于 2020-4-17 16:59 | 显示全部楼层
仔细看手册
手册上有好多BUG说明
 楼主| gavin87 发表于 2020-4-20 17:02 | 显示全部楼层
今天做AD测试,P1.2接3V电压,发现会偶尔输出0,其他大部分输出为A8,通过STC-ISP测试!  不知道有不有朋友也遇到过这个问题?? 怎么解决的??#include "reg51.h"
#include "intrins.h"
#define FOSC            11059200UL
#define BRT             (65536 - FOSC / 115200 / 4)
sfr     AUXR        =   0x8e;
sfr     T2H         =   0xd6;
sfr     T2L         =   0xd7;
sfr     ADC_CONTR   =   0xbc;
sfr     ADC_RES     =   0xbd;
sfr     ADC_RESL    =   0xbe;
sfr     ADCCFG      =   0xde;
sfr     P1M0        =   0x92;
sfr     P1M1        =   0x91;
bit busy;
char wptr;
char rptr;
char buffer[16];
void UartIsr() interrupt 4
    if (TI)
        TI = 0;
        busy = 0;
    if (RI)
        RI = 0;
        buffer[wptr++] = SBUF;
        wptr &= 0x0f;
void UartInit()
    SCON = 0x50;
    T2L = BRT;
    T2H = BRT >> 8;
    AUXR = 0x15;
    wptr = 0x00;
    rptr = 0x00;
    busy = 0;
void UartSend(char dat)
    while (busy);
    busy = 1;
    SBUF = dat;
void UartSendStr(char *p)
    while (*p)
        UartSend(*p++);
void main()
        unsigned char num=0;
    UartInit();
           P1M0 = 0x00;                                //设置P1.0为ADC口
    P1M1 = 0x04;
    ADCCFG = 0x0f;                              //设置ADC时钟为系统时钟/2/16/16
    ADC_CONTR = 0x80|0x02;                           //使能ADC模块
    ES = 1;
    EA = 1;
    UartSendStr("Uart Test !\r\n");
    while (1)
       ADC_CONTR |= 0x40;                      //启动AD转换
        _nop_();
        _nop_();
        while (!(ADC_CONTR & 0x20));            //查询ADC完成标志
        ADC_CONTR &= ~0x20;                     //清完成标志
        num = ADC_RES;                           //读取ADC结果
        UartSend(num);
