* 名 称:L6470_ConfigurationX
* 功 能:配置X号电机各参数
* 入口参数:
* 出口参数:
* 说 明:步进电机初始化设置
void L6470_ConfigurationX(void)
/* 初始化L6470各寄存器初值 */
dSPIN_Regs_Struct_Reset(&dSPIN_RegsStruct);
/* 加速率的设置为466 steps/s2,范围14.55至59590 steps/s2*/
dSPIN_RegsStruct.ACC = AccDec_Steps_to_Par(800);//466);
/* 减速率的设置为466 steps/s2,范围14.55至59590 steps/s2 */
dSPIN_RegsStruct.DEC = AccDec_Steps_to_Par(800);//466);
/* 最大速度设置为488步/秒,最大速度设置范围为15.25至15610步/秒*/
dSPIN_RegsStruct.MAX_SPEED = MaxSpd_Steps_to_Par(1000);
/* 最小速度设置为0步/秒,取值范围为0至976.3,步骤/秒*/
dSPIN_RegsStruct.MIN_SPEED = MinSpd_Steps_to_Par(0);
/* 全步进速度设置252步/秒,范围为7.63到15625步/秒*/
dSPIN_RegsStruct.FS_SPD = FSSpd_Steps_to_Par(2000);//252);
/*保持占空比(转矩)设定为10%,范围在0到99.6%*/
dSPIN_RegsStruct.KVAL_HOLD = Kval_Perc_to_Par(5);
/* 运行占空比(转矩)设定为10%,范围在0到99.6%*/
dSPIN_RegsStruct.KVAL_RUN = Kval_Perc_to_Par(10);
/* 加速的占空比(转矩)设定为10%,范围在0到99.6%*/
dSPIN_RegsStruct.KVAL_ACC = Kval_Perc_to_Par(10);
/* 减速的占空比(转矩)设定为10%,范围在0到99.6% */
dSPIN_RegsStruct.KVAL_DEC = Kval_Perc_to_Par(10);
/* 加速/减速曲线斜率的速度值。 range 0 to 3906 steps/s */
dSPIN_RegsStruct.INT_SPD = IntSpd_Steps_to_Par(200);//200);
/* 加减速——开始斜率(反电动势)BEMF补偿设置 0 to 0.4% s/step */
dSPIN_RegsStruct.ST_SLP = BEMF_Slope_Perc_to_Par(0.038);
/* 加速度——结束斜率(反电动势)BEMF补偿设置 0 to 0.4% s/step */
dSPIN_RegsStruct.FN_SLP_ACC = BEMF_Slope_Perc_to_Par(0.063);
/* 减速度——结束斜率(反电动势)BEMF补偿设置 0 to 0.4% s/step */
dSPIN_RegsStruct.FN_SLP_DEC = BEMF_Slope_Perc_to_Par(0.063);
/* 热补偿参数设置为1,范围为1-1.46875*/
dSPIN_RegsStruct.K_THERM = KTherm_to_Par(1);
/* 过流阈值设置1500毫安 */
dSPIN_RegsStruct.OCD_TH = dSPIN_OCD_TH_2250mA; //375mA//750mA//1125mA//1500mA//1875mA//2250mA//2625mA//3000mA//3375mA//3750mA//4125mA//4500mA//4875mA//5250mA//5625mA//6000mA
/* 失速阈值设置至1000mA,范围:31.25 to 4000mA */
dSPIN_RegsStruct.STALL_TH = StallTh_to_Par(3000);//1000
/* 设置到128微步模式 */
dSPIN_RegsStruct.STEP_MODE = dSPIN_STEP_SEL_1_128;
/* 报警设置 - 启用所有警报 */
dSPIN_RegsStruct.ALARM_EN = dSPIN_ALARM_EN_ALL_ENABLE;
//dSPIN_ALARM_EN_OVERCURRENT
//|dSPIN_ALARM_EN_THERMAL_SHUTDOWN
//|dSPIN_ALARM_EN_THERMAL_WARNING
//|dSPIN_ALARM_EN_UNDER_VOLTAGE
//|dSPIN_ALARM_EN_STALL_DET_A
//|dSPIN_ALARM_EN_STALL_DET_B;
//|dSPIN_ALARM_EN_SW_TURN_ON
//|dSPIN_ALARM_EN_WRONG_NPERF_CMD;
/* 内部振荡器,2MHz的的OSCOUT时钟,电源电压补偿禁用,启用过流关断,压摆率= 290 V /us,PWM频率为15.6kHz *///ENABLE// //过流关断
dSPIN_RegsStruct.CONFIG = dSPIN_CONFIG_INT_16MHZ_OSCOUT_2MHZ
| dSPIN_CONFIG_SW_HARD_STOP
| dSPIN_CONFIG_VS_COMP_DISABLE
| dSPIN_CONFIG_OC_SD_DISABLE
| dSPIN_CONFIG_SR_290V_us
| dSPIN_CONFIG_PWM_DIV_2
| dSPIN_CONFIG_PWM_MUL_1;
// Program all dSPIN registers
dSPIN_Registers_Set(&dSPIN_RegsStruct);
