UCOS-II 多任务,三个LED同时闪烁卡死
 楼主| 石头张 发表于 2020-4-25 09:48 | 显示全部楼层 |阅读模式
在UCOS-II多任务实验中,两个LED闪烁任务运行没问题,当三个LED闪烁任务同时运行时,程序就卡死在void HardFault_Handler(void)
了,请教大神,有人知道是什么问题吗?
int main(void)
        BSP_Init();
        OSInit();
        OSTaskCreate(Task_Start,(void *)0,
                &startup_task_stk[STARTUP_TASK_STK_SIZE-1],STARTUP_TASK_PRIO);
        OSStart();
        return 0;
void Task_Start(void *p_arg)
        (void)p_arg;
        OSTaskCreate(Task_LED1,(void *)0,
                           &task_led1_stk[TASK_LED1_STK_SIZE-1],
                     TASK_LED1_PRIO);
        OSTaskCreate(Task_LED2,(void *)0,
                           &task_led2_stk[TASK_LED2_STK_SIZE-1],
                     TASK_LED2_PRIO);
        OSTaskCreate(Task_LED3,(void *)0,
                           &task_led2_stk[TASK_LED3_STK_SIZE-1],
                     TASK_LED3_PRIO);
        while(1)
                OSTimeDlyHMSM(0,0,0,50);
void Task_LED1(void *p_arg)
        (void)p_arg;
        while(1)
                LED1(ON);
                OSTimeDlyHMSM(0,0,0,100);
                LED1(OFF);
void Task_LED2(void *p_arg)
        (void)p_arg;
        while(1)
                LED2(ON);
                OSTimeDlyHMSM(0,0,0,200);
                LED2(OFF);
void Task_LED3(void *p_arg)
        (void)p_arg;
        while(1)
                LED3(ON);
                OSTimeDlyHMSM(0,0,0,300);
                LED3(OFF);
#ifndef __APP_CFG_H__
#define __APP_CFG_H__
#define STARTUP_TASK_PRIO       4
#define TASK_LED1_PRIO          5
#define TASK_LED2_PRIO          6
#define TASK_LED3_PRIO          7
#define STARTUP_TASK_STK_SIZE   80
#define TASK_LED1_STK_SIZE      80
#define TASK_LED2_STK_SIZE      80
#define TASK_LED3_STK_SIZE      80
#endif
你瞅啥 发表于 2020-4-25 18:33 | 显示全部楼层
STK_SIZE too small
