Proteus8.9 仿真STM32407ZGT6系列004_独立看门狗
 楼主| kaillen 发表于 2020-5-3 23:19 | 显示全部楼层 |阅读模式
一,打开文件(可以随文下载放置在文档中打开)。(如下图1所示)
图1
二,调整虚拟器件,另存工程文件。(如下图2,3所示)
图2
图3
三,点击Source Code标签。(如下图4所示)
图4
四,编辑main.c, iwdg.c,iwdg.h,key.c, key.h,led.c, led.h 代码如Proteus8.9 仿真STM32407ZGT6系列001(如下图5所示)
图5
五,Main.c 代码:
#include "stm32f4xx_conf.h"
#include "sys.h"
#include "delay.h"
#include "usart.h"
#include "led.h"
#include "key.h"
#include "iwdg.h"
int main(void)
       NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
       delay_init(168);
       LED_Init();
       KEY_Init();
    delay_ms(500);
       IWDG_Init(4,1000);
       LED0=0;
       LED1=1;
       while(1)
              if(KEY0 ==1)
                     IWDG_Feed();
              delay_ms(10);
iwdg.c代码:
#include "iwdg.h"
#include "led.h"
void IWDG_Init(u8 prer,u16 rlr)
       IWDG_WriteAccessCmd(IWDG_WriteAccess_Enable);
       IWDG_SetPrescaler(prer);
       IWDG_SetReload(rlr);
       IWDG_ReloadCounter();//reload
       IWDG_Enable();
void IWDG_Feed(void)
       LED0=~PBin(6);
    LED1=0;
iwdg.h代码:
#ifndef _IWDG_H
#define _IWDG_H
#include "sys.h"
void IWDG_Init(u8 prer,u16 rlr);
void IWDG_Feed(void);
#endif
led.c代码:
#include "led.h"
void LED_Init(void)
  GPIO_InitTypeDef  GPIO_InitStructure;
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB, ENABLE);//使能GPIOB时钟
  //GPIOF9,F10初始化设置
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6| GPIO_Pin_8;//LED对应引脚
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;//普通输出模式
  GPIO_InitStructure.GPIO_OType= GPIO_OType_PP;//推挽输出
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;//100MHz
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;//上拉
  GPIO_Init(GPIOB,&GPIO_InitStructure);//初始化
led.h代码:
#ifndef __LED_H
#define __LED_H
#include "sys.h"
//LED端口定义
#define LED0 PBout(6) // LED0
#define LED1 PBout(8) // LED1
void LED_Init(void);//初始化
#endif
key.c代码:
#include "key.h"
#include "delay.h"
void KEY_Init(void)
       RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB,ENABLE);//使能GPIOB时钟
       GPIO_InitStructure.GPIO_Pin= GPIO_Pin_3; //KEY0 对应引脚
       GPIO_InitStructure.GPIO_Mode= GPIO_Mode_IN;//普通输入模式
       GPIO_InitStructure.GPIO_Speed= GPIO_Speed_100MHz;//100M
       GPIO_InitStructure.GPIO_PuPd= GPIO_PuPd_DOWN ;//下拉
       GPIO_Init(GPIOB,&GPIO_InitStructure);//初始化GPIOE4
key.h代码:
#ifndef __KEY_H
#define __KEY_H
#include "sys.h"
#define KEY0              PBin(3)        //PB3
void KEY_Init(void);    //IO初始化
#endif
六,点击构建工程按钮,编译工程。(如下图6所示)
图6
七,点击窗口左下方仿真按钮,可见黄灯点亮仿真,按下按钮,进行喂狗,开始跳闪仿真。 (如下图7,8,9所示)
图7
图8
图9
八,选择release,点击构建工程按钮,编译工程生成Hex文件。(如下图10所示)
图10
九, 系列的001-003虚拟仿真与开发板对应已证明:虚拟仿真程序对于开发板有效,之后不再➕上下载到开发板的介绍。
需要进一步了解,请加入QQ群:976235464
xyz549040622 发表于 2020-5-4 08:14 | 显示全部楼层
proteus已经这么强大了。。。
