FFT算法后的谐波数据分析
 楼主| 肉坨坨 发表于 2019-11-22 18:30 | 显示全部楼层 |阅读模式
#define NUM_FFT 128 // Length of FFT to process
typedef struct
//        s16 iRealArray[NUM_FFT];
//        s16 iMageArray[NUM_FFT];
        float iRealArray[NUM_FFT];
        float iMageArray[NUM_FFT];
        u16        FU[3];        //---基波电压---NNN.N6
        u32        FI[4];        //---基波电流NNNN.NNNN
        u32        HarmonicpercentU[51];
        u32        HarmonicpercentI[51];        //---谐波含有率--NNN.N6
}sDl645FftHarmonicData_TypeDef;
sDl645FftHarmonicData_TypeDef        HarmonicData;
         float ftemp;
        for(i=0;i<NUM_FFT;i++)        HarmonicData.iMageArray = 0;
        FFT(HarmonicData.iRealArray, HarmonicData.iMageArray);
        ftemp_N = (float)(((float)HarmonicData.iRealArray[1] *(float)HarmonicData.iRealArray[1]) + ((float)HarmonicData.iMageArray[1] * (float)HarmonicData.iMageArray[1]));
这步之后ftemp就为0了,哪里出错了?
