- /* Copyright(c) 2019 Nuvoton Technology Corp. All rights reserved. */
- // Website: http://www.nuvoton.com
- // E-Mail : MicroC-8bit@nuvoton.com
- #include "ML51.h"
- * [url=home.php?mod=space&uid=247401]@brief[/url] PWM Synchronous mode PWM0 channel 0/2/4 setting and channel 1/3/4 follow output demo
- * @param None
- * [url=home.php?mod=space&uid=266161]@return[/url] None
- * [url=home.php?mod=space&uid=1543424]@Details[/url] Channel 0 high duty 10%, Channel 2 high duty 30% , Channel 4 high duty 50%.
- void main (void)
- /** PWM0 initial setting
- * include pwm.c in Library for PWM mode setting
- * @note: the period setting of all PWM0 should be same, for example following 0x6FF.
- PWM0_ClockSource(PWM_FSYS,128); // define PWM0 clock source and divider.
- MFP_P05_PWM0_CH0; // multi function pin define P0.5 as PWM0 channel 0 output
- P05_PUSHPULL_MODE;
- MFP_P24_PWM0_CH1; // multi function pin define P2.4 as PWM0 channel 1 output
- P24_PUSHPULL_MODE;
- PWM0_ConfigOutputChannel(0,Synchronous,EdgeAligned,0x6FF,10); // setting PWM channel 0&1 as 10% duty high of 0x6FF PWM period = 0x00B3
- MFP_P03_PWM0_CH2; // multi function pin define P0.3 as PWM0 channel 2 output
- P03_PUSHPULL_MODE;
- MFP_P22_PWM0_CH3; // multi function pin define P2.2 as PWM0 channel 3
- P22_PUSHPULL_MODE;
- PWM0_ConfigOutputChannel(2,Synchronous,EdgeAligned,0x6FF,30); // setting PWM channel 2&3 as 30% duty high of 0x6FF PWM period = 0x0219
- MFP_P01_PWM0_CH4; // multi function pin define P0.1 as PWM0 channel 4
- P01_PUSHPULL_MODE;
- MFP_P20_PWM0_CH5; // multi function pin define P0.5 as PWM0 channel 5
- P20_PUSHPULL_MODE;
- PWM0_ConfigOutputChannel(4,Synchronous,EdgeAligned,0x6FF,50); // setting PWM channel 4&5 as 50% duty high of 0x6FF PWM period = 0x037F
- PWM0_RUN();
- while(1);
