如何在需要时开启外部中断,不需要时关闭中断?
 楼主| 冷冻链 发表于 2019-11-28 08:52 | 显示全部楼层 |阅读模式
EXTI_InitTypeDef   EXTI_InitStructure;
GPIO_InitTypeDef   GPIO_InitStructure;
                /* config the extiline clock  */
          RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD,ENABLE);
                /* EXTI line gpio config*/
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;         // 上拉输入
  GPIO_Init(GPIOD, &GPIO_InitStructure);
                /* EXTI line mode config */
  GPIO_EXTILineConfig(GPIO_PortSourceGPIOD, GPIO_PinSource6);
  EXTI_InitStructure.EXTI_Line = EXTI_Line6;
  EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;
  EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Falling; //下降沿中断
  EXTI_InitStructure.EXTI_LineCmd = ENABLE;
  EXTI_Init(&EXTI_InitStructure);
如果要在其他地方需要失能PD6这个中断,该怎么做?
