请大家,看看这个程序,是八路抢答去,仿真时有问题。
 楼主| st_0001 发表于 2011-12-26 17:41 | 显示全部楼层 |阅读模式
#include<reg51.h>
#define uchar unsigned char
#define uint unsigned int
sbit e = P2^1;
sbit rs = P2^0;                /*液晶引脚                  */
sbit sp1 = P3;                 /*  键盘扫描按键                */
sbit sp2 = P1^6;                  /*主持人开关                  */
sbit spk = P1^7;
uchar tabe[] = "  welcom your ";
uchar tabe1[] = "  00  ";                   /* 开始显示                  */
uchar tabe2[] = "dao ji shiji ";                  /*14  倒计时                */
uchar tabe3[] = "   error   ";
uchar tabe4[] = "wu renqian da";                        /* 开始答题                        */
uchar tabe5[] = " hui da shij ";                        /*回答时间                  */
uchar tabe6[] = " wu ren hui da";                         /*无人回答                        */
uchar tabe7[] = "    end     ";
uchar num1,temp;
uchar c;
uchar y;
uchar count,falg;
uchar ss,gg;  //定时器  计数
uchar miao,feng,shi;          //显示数字
delay1ms(uchar n)
        uchar i,j;
        while(n --)
                for(i = 1; i > 0 ; i --)
                for(j = 248; j > 0 ; j --);
//  液晶设置
write_com(uchar cm)
        rs = 0;
        P0 = cm;
        delay1ms(1);
        e = 1;
        delay1ms(1);
        e = 0;
write_dat(uchar da)
        rs = 1;
        P0 = da;
        delay1ms(1);
        e = 1;
        delay1ms(1);
        e = 0;
add_dat(uchar ad,uchar shuji)
        uchar ge;
        ge = shuji%10;
        write_com(0x80 + 0x40+ ad);
        write_dat(0x30 + ge);
/*  液晶设置         */
init()           /*初始化设置                 */
        uchar x;
        e = 0;
        write_com(0x38);
        write_com(0x0e);
        write_com(0x06);
        delay1ms(1);
        write_com(0x01);
        delay1ms(10);
        for(x = 0; x < 15 ; x ++)
          write_dat(tabe[x]);
        write_com(0x80 + 0x43);
        for(x = 0; x < 6 ; x ++)
                write_dat(tabe1[x]);
init1()           /*定时器 初始化                 */
        TMOD = 0x11;
        TH0 = (65536 - 50000)/256;
        TL0 = (65536 - 50000)%256;
        ET1 = 1;
        EA = 1;
        ET0 = 1;
        gg = 0;
        ss = 0 ;
        count = 0;
        miao= 5;
        feng = 9;
        shi = 8;
uint keyscan()
                        P3=0xfe;
                        temp=P3;
                        temp=temp&0xf0;
                        while(temp!=0xf0)
                                        delay1ms(1);
                                        temp=P3;
                                        temp=temp&0xf0;
                                        while(temp!=0xf0)
                                                temp=P3;
                                        switch(temp)
                                                        case 0xee:num1=1;        break;
                                                        case 0xde:num1=2;        break;
                                                        case 0xbe:num1=3;        break;
                                                        case 0x7e:num1=4;   break;
                                        while(temp!=0xf0)
                                                        temp=P3;
                                                        temp=temp&0xf0;
                        P3=0xfd;
                        temp=P3;
                        temp=temp&0xf0;
                        while(temp!=0xf0)
                                        delay();
                                        temp=P3;
                                        temp=temp&0xf0;
                                        while(temp!=0xf0)
                                                temp=P3;
                                        switch(temp)
                                                        case 0xed:num1=5;        break;
                                                        case 0xdd:num1=6;        break;
                                                        case 0xbd:num1=7;        break;
                                                        case 0x7d:num1=8;        break;
                                        while(temp!=0xf0)
                                                        temp=P3;
                                                        temp=temp&0xf0;
return num1;
dispaly()
              c = keyscan();
                while(c)
                                  TR0 = 0;
                                  TR1 = 0;
                                  write_com(0x01);
                                  delay1ms(1);
                                  write_com(0x80 + 0x10);         // 抢答错误
                                  for(y = 0; y < 10;y++)
                                           write_dat(tabe3[y]);
                                   write_com(0x80 + 0x45);
                                delay1ms(1);
                                  write_dat(0x30 + c);
dispaly1()
              c = keyscan();
                while(c)
                                  delay1ms(10);
                                  write_com(0x01);
                                  delay1ms(1);
                                  for(y = 0; y < 9;y++)
                                           write_dat(tabe5[y]);
                                delay1ms(1);
                                  delay1ms(10);
                                   TR0 = 1;
                                   falg =2;
                                   TR1 = 0;
                                   c =         0;
speak()
        uchar i;
        for(i = 200; i > 0; i --)
                spk = ~spk;
                delay1ms(5);
main()
        init();
           init1();
           delay1ms(10);
           write_com(0x81);
        delay1ms(5);
        spk = 0;
   while(1)
                     if(sp2 == 0)
                                delay1ms(5);
                                   if(sp2 == 0)
                                          count ++;
                                        switch(count)
                                                case  1:        falg = 1;TR1 = 0;TR0 =1;        break;
                                                case  2:         TR0 = 0;TR1=0;falg = 0;        break;
                                                case  3:         init();init1();        break;
                                          while(sp2 == 0);
                                        do{delay1ms(5);}
                                        while(sp2 == 0);
void to() interrupt 1
        TL0 = (65536 - 50000)%256;         // 50ms
         ss++;
                                    if(falg == 1)
                                                   dispaly();
                                                   if(ss == 50)
                                                        {          ss= 0;
        miao --;
        if(miao == 0)         // 调至第二步
        TR1 = 1;
        TR0 = 0;
        write_com(0x80 + 0x01);
        for(y = 0 ; y <13 ;y ++)        //  显示倒计时 8 秒
        write_dat(tabe2[y]);
        delay1ms(1);
        add_dat(6,miao);
        speak();
                                   if(falg == 2)
                                              if(ss == 50)
                                                           ss = 0;
                                                        shi --;
        delay1ms(1);
        add_dat(6,shi);
        if(shi == 0)
        for(y = 0 ; y <9 ;y ++)           //  结束
        write_dat(tabe7[y]);
        delay1ms(1);
        TR0 = 0;
        TR1 = 0;
        falg = 0;
void t1() interrupt 3
        TH1=(65536-50000)/256;
        TL1=(65536-50000)%256;
                        gg++;
                 dispaly1();
                if(gg == 50)
                          gg= 0;
                        feng --;
                        if(feng == 0)         // 无人抢答回答
                                TR1 = 0;
                                TR0 = 0;
                                for(y = 0 ; y <15 ;y ++)
                                         delay1ms(1);
                                add_dat(6,feng);
                        for(y = 0 ; y <15 ;y ++)        //  显示抢答时时间 8 秒
                                 write_dat(tabe4[y]);
                                 delay();
                        add_dat(6,feng);
 楼主| st_0001 发表于 2011-12-26 17:42 | 显示全部楼层
请大家看看,小弟实在是头晕了,不知道问题在哪里。万分感激。。。
