/*---------------------------------------------------------------------------------------------------------*/ /* */ /* Copyright(c) 2019 Nuvoton Technology Corp. All rights reserved. */ /* */ /*---------------------------------------------------------------------------------------------------------*/ //*********************************************************************************************************** // Website: http://www.nuvoton.com // E-Mail : MicroC-8bit@nuvoton.com // Date : Jun/21/2019 //*********************************************************************************************************** //*********************************************************************************************************** // File Function: MS51_8K Access SPI Flash (W25Q16BV) demo code //*********************************************************************************************************** #include "MS51_32K.h" #define SS P15 #define WRITE_ENABLE 0x06 #define WRITE_DISABLE 0x04 #define READ_DATA 0x03 #define PAGE_PROGRAM 0x02 #define CHIP_ERASE 0xC7 #define READ_STATUS1 0x05 //----------------------------------------------------------------------------------------------------------- void SPI_Error(void) { printf ("\n* SPI Error, please check the connection between MCU and SPI Flash"); while(1); } //----------------------------------------------------------------------------------------------------------- void SPI_Initial(void) { /* /SS General purpose I/O ( No Mode Fault ) */ set_SPSR_DISMODF; clr_SPCR_SSOE; /* SPI in Master mode */ set_SPCR_MSTR; /* MSB first */ clr_SPCR_LSBFE; clr_SPCR_CPOL; clr_SPCR_CPHA; /* Enable SPI function */ set_SPCR_SPIEN; } //----------------------------------------------------------------------------------------------------------- void Read_MID_DID(UINT8 *pu8MID,UINT8 *pu8DID) { SS = 0; SPDR = 0x90; while((SPSR&0x80)==0x00); clr_SPSR_SPIF; SPDR = 0x00; while((SPSR&0x80)==0x00); clr_SPSR_SPIF; SPDR = 0x00; while((SPSR&0x80)==0x00); clr_SPSR_SPIF; SPDR = 0x00; while((SPSR&0x80)==0x00); clr_SPSR_SPIF; SPDR = 0xFF; while((SPSR&0x80)==0x00); *pu8MID = SPDR; clr_SPSR_SPIF; SPDR = 0xFF; while((SPSR&0x80)==0x00); *pu8DID = SPDR; clr_SPSR_SPIF; SS = 1; } //----------------------------------------------------------------------------------------------------------- void Flash_Write_Enable(void) { SS = 0; SPDR = WRITE_ENABLE; while((SPSR&0x80)==0x00); clr_SPSR_SPIF; SS = 1; } //----------------------------------------------------------------------------------------------------------- void Flash_Write_Disable(void) { SS = 0; SPDR = WRITE_DISABLE; while((SPSR&0x80)==0x00); clr_SPSR_SPIF; SS = 1; } //----------------------------------------------------------------------------------------------------------- void Flash_Chip_Erase(void) { SS = 0; SPDR = CHIP_ERASE; while((SPSR&0x80)==0x00); clr_SPSR_SPIF; SS = 1; } //----------------------------------------------------------------------------------------------------------- void Flash_Read_Status(void) { UINT8 u8Status; SS = 0; do{ SPDR = READ_STATUS1; while((SPSR&0x80)==0x00); clr_SPSR_SPIF; SPDR = 0xFF; while((SPSR&0x80)==0x00); u8Status = SPDR; clr_SPSR_SPIF; }while((u8Status&0x01)==0x01); SS = 1; } //----------------------------------------------------------------------------------------------------------- void Flash_Erase_Verify(void) { UINT16 u16CNT; UINT8 u8Data; SS = 0; SPDR = READ_DATA; while((SPSR&0x80)==0x00); clr_SPSR_SPIF; /* 24-bit Address */ SPDR = 0x00; while((SPSR&0x80)==0x00); clr_SPSR_SPIF; SPDR = 0x00; while((SPSR&0x80)==0x00); clr_SPSR_SPIF; SPDR = 0x00; while((SPSR&0x80)==0x00); clr_SPSR_SPIF; for(u16CNT=0;u16CNT<256;u16CNT++) { SPDR = 0x00; while((SPSR&0x80)==0x00); u8Data = SPDR; clr_SPSR_SPIF; if(u8Data != 0xFF) { SPI_Error(); } } SS = 1; } //----------------------------------------------------------------------------------------------------------- void Flash_Program(void) { UINT16 u16CNT; SS = 0; SPDR = PAGE_PROGRAM; while((SPSR&0x80)==0x00); clr_SPSR_SPIF; /* 24-bit Address */ SPDR = 0x00; while((SPSR&0x80)==0x00); clr_SPSR_SPIF; SPDR = 0x00; while((SPSR&0x80)==0x00); clr_SPSR_SPIF; SPDR = 0x00; while((SPSR&0x80)==0x00); clr_SPSR_SPIF; /* Send the data to SPI_Flash buffer */ for(u16CNT=0;u16CNT<256;u16CNT++) { SPDR = (UINT8)u16CNT; while((SPSR&0x80)==0x00); clr_SPSR_SPIF; } SS = 1; } //----------------------------------------------------------------------------------------------------------- void Flash_Program_Verify(void) { UINT16 u16CNT; UINT8 u8Data; SS = 0; SPDR = READ_DATA; while((SPSR&0x80)==0x00); clr_SPSR_SPIF; /* 24-bit Address */ SPDR = 0x00; while((SPSR&0x80)==0x00); clr_SPSR_SPIF; SPDR = 0x00; while((SPSR&0x80)==0x00); clr_SPSR_SPIF; SPDR = 0x00; while((SPSR&0x80)==0x00); clr_SPSR_SPIF; for(u16CNT=0;u16CNT<256;u16CNT++) { SPDR = 0x00; while((SPSR&0x80)==0x00); u8Data = SPDR; clr_SPSR_SPIF; if(u8Data != (UINT8)u16CNT) { SPI_Error(); } } SS = 1; } //----------------------------------------------------------------------------------------------------------- void main(void) { UINT8 u8MID,u8DID; /* Note MCU power on system clock is HIRC (22.1184MHz), so Fsys = 22.1184MHz */ MODIFY_HIRC(HIRC_24); ALL_GPIO_QUASI_MODE; UART_Open(240000000,UART0_Timer3,115200); /* 9600 Baud Rate*/ ENABLE_UART0_PRINTF; SPI_Initial(); Read_MID_DID(&u8MID,&u8DID); if((u8MID != 0xEF)&&(u8DID != 0x14)) { SPI_Error(); } /* The procedure of SPI Flash at erase mode */ Flash_Write_Enable(); Flash_Chip_Erase(); Flash_Read_Status(); Flash_Write_Disable(); Flash_Erase_Verify(); /* The procedure of SPI Flash at program mode */ Flash_Write_Enable(); Flash_Program(); Flash_Read_Status(); Flash_Write_Disable(); /* Program verify */ Flash_Program_Verify(); printf("\nFinished the SPI Demo Code and test pass!!!\n"); while(1); } //-----------------------------------------------------------------------------------------------------------
举报
本版积分规则 发表回复 回帖并转播 回帖后跳转到最后一页
人才类勋章
发帖类勋章
等级类勋章
时间类勋章
231
3196
扫码关注 21ic 官方微信
扫码关注嵌入式微处理器
扫码关注电源系统设计
扫码关注21ic项目外包
扫码浏览21ic手机版
本站介绍 | 申请友情链接 | 欢迎投稿 | 隐私声明 | 广告业务 | 网站地图 | 联系我们 | 诚聘英才
京公网安备 11010802024343号
