[51单片机] 51单片机单按键多击程序遇到问题
 楼主| daiya1981 发表于 2020-7-5 20:17 | 显示全部楼层 |阅读模式
写了一个响应单按键多击的程序,按键弹起大于0.5S后返回键值,有问题,无法运行。可是我才疏学浅,找不到问题出在哪里。请各位高人帮忙看看问题出在哪?
#include <reg52.h>
sbit LED0 = P1^0;
sbit LED1 = P1^1;
sbit LED2 = P1^2;
sbit KEY1 = P3^2;
unsigned int count = 0,ClickFlag = 0,ClickFlagCount = 0,LongClickFlag = 0;
unsigned char i = 0,Click = 0;
unsigned char keynum = 0;
unsigned char keyscan(void)
    if(KEY1)
        if(count > 30 && count < 3000)
                ClickFlag = 1;
                keynum++;
        count = 0;
        if(ClickFlag == 1)
            if(ClickFlagCount++ > 500)
                ClickFlag = 0;
                ClickFlagCount = 0;
                return keynum;
                keynum = 0;
            else
                ClickFlag = 0;
                ClickFlagCount = 0;
        else
            ClickFlagCount = 0;
    else
        count++;
        if(count > 3000)
            count = 3001;
    return 0;
void main()
    EA = 1;       //使能总中断
    TMOD = 0x01;  //设置T0为模式1
    TH0  = 0xFC;  //为T0赋初值0xFC67,定时1ms
    TL0  = 0x67;
    ET0  = 1;     //使能T0中断
    TR0  = 1;     //启动T0
    while (1)
        if(i==1)
            LED0 = ~LED0;
        if(i==2)
            LED1 = ~LED1;
        if(i==3)
            LED2 = ~LED2;
/* 定时器0中断服务函数 */
void InterruptTimer0() interrupt 1
    TH0 = 0xFC;  //重新加载初值
    TL0 = 0x67;
    i = keyscan();
LcwSwust 发表于 2020-7-5 20:44 | 显示全部楼层
这个逻辑有问题:
else
       ClickFlagCount = 0;
 楼主| daiya1981 发表于 2020-7-6 08:19 | 显示全部楼层
我改掉了,可是程序对于按键击发还是没反应
#include <reg52.h>
sbit LED0 = P1^0;
sbit LED1 = P1^1;
sbit LED2 = P1^2;
sbit KEY1 = P3^2;
unsigned int count = 0,ClickFlagCount = 0;
unsigned char i = 0,ClickFlag = 0,keynum = 0;
        if(KEY1)
                                ClickFlag = 1;
                                keynum++;
            count = 0;
            if(ClickFlag == 1)
                                 ClickFlag = 0;
                                return keynum;
                                keynum = 0;
                else
                                ClickFlag = 0;
            else
                        ClickFlagCount = 0;
        else
                count++;
                if(count > 3000)
                        count = 3001;
        return 0;
void main()
     EA = 1;       //使能总中断
    TL0  = 0x67;
    ET0  = 1;     //使能T0中断
    TR0  = 1;     //启动T0
    while (1)
                switch (i)
            case 1:
                LED0 = ~LED0;
                break;
            case 2:
                LED1 = ~LED1;
                break;
            case 3:
                LED2 = ~LED2;
                break;
            default:
                break;
/* 定时器0中断服务函数 */
    TL0 = 0x67;
    i = keyscan();
coody 发表于 2020-7-6 10:47 | 显示全部楼层
我觉得很简单的处理,每次按下都记录时刻,跟上一时刻比较即可。我的产品经常要一个键有多击和长按,比如播放器,长按3秒开机,长按3秒关机,短单击播放、暂停,双击进入设置。
 楼主| daiya1981 发表于 2020-7-6 11:25 | 显示全部楼层
我添加了注释,不知道可不可以看清楚逻辑了?
    if(KEY1)
        if(count > 30 && count < 3000)    //如果按下时间30ms~3s,认为是单击
                ClickFlag = 1;    //按键抬起标志置1
                keynum++;    //键号加1
        count = 0;    // 键按下时间计数器清0
        if(ClickFlag == 1)    //如果按键抬起标志为1
            if(ClickFlagCount++ > 500)    //按键抬起时间大于0.5s
                ClickFlag = 0;    //按键抬起标志清0
                return keynum;    //返回键号
                keynum = 0;    //键号清0
            else    //按键抬起时间小于0.5s
                ClickFlag = 0;
        else    //如果按键抬起标志为0
            ClickFlagCount = 0;    //清0按键抬起时间计数器
    else
        count++;    //按键按下时间计数器加1
        if(count > 3000)    //防止数据溢出
            count = 3001;
    return 0;
ayb_ice 发表于 2020-7-7 10:29 | 显示全部楼层
#include <reg52.h>
sbit LED0 = P1^0;
sbit LED1 = P1^1;
sbit LED2 = P1^2;
sbit KEY1 = P3^2;
typedef struct{
        bit bBkpGpio;
        u08 ucPushNum;
        u16 usPopCnt;
        u08 ucScaleCnt;
        u08 ucNum;
}Key_Typedef;
Key_Typedef stKey;
bit keyscan(void)
        bit bThisGpio;
        bit bRtn = 0;
        if (++stKey.ucScaleCnt >= 10)
                stKey.ucScaleCnt = 0;
                bThisGpio = KEY1;
                if (bThisGpio)
                        if (++stKey.usPopCnt >= 500/10)
                                stKey.ucNum = stKey.ucPushNum;
                                stKey.ucPushNum = 0;
                                bRtn  = 1;
                if (bThisGpio != stKey.bBkpGpio)
                        if (!bThisGpio)
                                stKey.ucPushNum++;
                                stKey.usPopCnt = 0;
                        stKey.bBkpGpio = bThisGpio;
        return bRtn;
u08 ucLedMode;
void main()
    EA = 1;       //使能总中断
    TL0  = 0x67;
    ET0  = 1;     //使能T0中断
    TR0  = 1;     //启动T0
    while (1)
        if(ucLedMode==1)
            LED0 = ~LED0;
        if(i==2)
            LED1 = ~LED1;
        if(ucLedMode==3)
            LED2 = ~LED2;
/* 定时器0中断服务函数 */
    TL0 = 0x67;
        if (keyscan())
                ucLedMode = stKey.ucNum;
 楼主| daiya1981 发表于 2020-7-7 11:49 | 显示全部楼层
谢谢各位,愿好人一生平安!
