STM32H7的摄像头接口DCMI配套的函数HAL_DCMI_Start_DMA非常不错,支持大分辨率直接传输
 楼主| 社畜一枚 发表于 2018-8-9 21:30 | 显示全部楼层 |阅读模式
函数HAL_DCMI_Start_DMA封装的通用定时器DMA1,DMA2。使用这个定时器的特点是限制单轮最大65535次传输,这样使用大分辨率摄像头非常不方便。
使用这个函数的话,解决了这个问题,程序里面做了一个处理,对于需要大于65536次传输的情况,使用了双缓冲,不断动态调整地址,直到一帧传输完毕后会使能DCMI的帧中断
  * @brief  Enables DCMI DMA request and enables DCMI capture
  * @param  hdcmi:     pointer to a DCMI_HandleTypeDef structure that contains
  *                    the configuration information for DCMI.
  * @param  DCMI_Mode: DCMI capture mode snapshot or continuous grab.
  * @param  pData:     The destination memory Buffer address (LCD Frame buffer).
  * @param  Length:    The length of capture to be transferred.
  * @retval HAL status
HAL_StatusTypeDef HAL_DCMI_Start_DMA(DCMI_HandleTypeDef* hdcmi, uint32_t DCMI_Mode, uint32_t pData, uint32_t Length)
  /* Initialize the second memory address */
  uint32_t SecondMemAddress = 0;
  /* Check function parameters */
  assert_param(IS_DCMI_CAPTURE_MODE(DCMI_Mode));
  /* Process Locked */
  __HAL_LOCK(hdcmi);
  /* Lock the DCMI peripheral state */
  hdcmi->State = HAL_DCMI_STATE_BUSY;
  /* Enable DCMI by setting DCMIEN bit */
  __HAL_DCMI_ENABLE(hdcmi);
  /* Configure the DCMI Mode */
  hdcmi->Instance->CR &= ~(DCMI_CR_CM);
  hdcmi->Instance->CR |=  (uint32_t)(DCMI_Mode);
  /* Set the DMA memory0 conversion complete callback */
  hdcmi->DMA_Handle->XferCpltCallback = DCMI_DMAXferCplt;
  /* Set the DMA error callback */
  hdcmi->DMA_Handle->XferErrorCallback = DCMI_DMAError;
  /* Set the dma abort callback */
  hdcmi->DMA_Handle->XferAbortCallback = NULL;
  /* Reset transfer counters value */
  hdcmi->XferCount = 0;
  hdcmi->XferTransferNumber = 0;
  if(Length <= 0xFFFF)
    /* Enable the DMA Stream */
    HAL_DMA_Start_IT(hdcmi->DMA_Handle, (uint32_t)&hdcmi->Instance->DR, (uint32_t)pData, Length);
  else /* DCMI_DOUBLE_BUFFER Mode */
    /* Set the DMA memory1 conversion complete callback */
    hdcmi->DMA_Handle->XferM1CpltCallback = DCMI_DMAXferCplt;
    /* Initialize transfer parameters */
    hdcmi->XferCount = 1;
    hdcmi->XferSize = Length;
    hdcmi->pBuffPtr = pData;
    /* Get the number of buffer */
    while(hdcmi->XferSize > 0xFFFF)
      hdcmi->XferSize = (hdcmi->XferSize/2);
      hdcmi->XferCount = hdcmi->XferCount*2;
    /* Update DCMI counter  and transfer number*/
    hdcmi->XferCount = (hdcmi->XferCount - 2);
    hdcmi->XferTransferNumber = hdcmi->XferCount;
    /* Update second memory address */
    SecondMemAddress = (uint32_t)(pData + (4*hdcmi->XferSize));
    /* Start DMA multi buffer transfer */
    HAL_DMAEx_MultiBufferStart_IT(hdcmi->DMA_Handle, (uint32_t)&hdcmi->Instance->DR, (uint32_t)pData, SecondMemAddress, hdcmi->XferSize);
  /* Enable Capture */
  hdcmi->Instance->CR |= DCMI_CR_CAPTURE;
  /* Release Lock */
  __HAL_UNLOCK(hdcmi);
  /* Return function status */
  return HAL_OK;
