[USB编程] 如何获取双descriptor的数据
 楼主| liuqiong023 发表于 2020-8-31 16:51 | 显示全部楼层 |阅读模式
大家好,我想问一个USB hid的问题。
如果我的USB设备是单描述符,下面的代码是可以的。
但是如果我USB设备时双描述符, 下面的代码只能获取到第一个descriptor的值,但是获取不到第二个descriiptor的值。
    GUID                                hidGuid;        /* GUID for HID driver */
    HDEVINFO                            deviceInfoList;
    SP_DEVICE_INTERFACE_DATA            deviceInfo;
    SP_DEVICE_INTERFACE_DETAIL_DATA     *deviceDetails = NULL;
    DWORD                               size;
    int                                 i, openFlag = 0;  /* may be FILE_FLAG_OVERLAPPED */
    int                                 errorCode = USBOPEN_ERR_NOTFOUND;
    HANDLE                              handle = INVALID_HANDLE_VALUE;
    HIDD_ATTRIBUTES                     deviceAttributes;
    HidD_GetHidGuid(&hidGuid);
    deviceInfoList = SetupDiGetClassDevs(&hidGuid, NULL, NULL, DIGCF_PRESENT | DIGCF_INTERFACEDEVICE);
    deviceInfo.cbSize = sizeof(deviceInfo);
    for(i=0;; i++) {
        if(handle != INVALID_HANDLE_VALUE) {
            CloseHandle(handle);
        if(!SetupDiEnumDeviceInterfaces(deviceInfoList, 0, &hidGuid, i, &deviceInfo))
            break;  /* no more entries */
        /* first do a dummy call just to determine the actual size required */
        SetupDiGetDeviceInterfaceDetail(deviceInfoList, &deviceInfo, NULL, 0, &size, NULL);
        if(deviceDetails != NULL)
            free(deviceDetails);
        deviceDetails = malloc(size);
        deviceDetails->cbSize = sizeof(*deviceDetails);
        /* this call is for real: */
        SetupDiGetDeviceInterfaceDetail(deviceInfoList, &deviceInfo, deviceDetails, size, &size, NULL);
        DEBUG_PRINT(("checking HID path \"%s\"\n", deviceDetails->DevicePath));
        /* attempt opening for R/W -- we don't care about devices which can't be accessed */
        handle = CreateFile(deviceDetails->DevicePath, GENERIC_READ|GENERIC_WRITE, FILE_SHARE_READ|FILE_SHARE_WRITE, NULL, OPEN_EXISTING, openFlag, NULL);
        if (!HidD_GetPreparsedData(handle ,&PreparsedData))
                        //doing
                if(!HidP_GetCaps(PreparsedData,&Capabilities))
                 //doing
