[技术求助] zstack 3.0.2 通过AF_DataRequest发送和接收数据的问题
 楼主| 开心阳 发表于 2020-9-1 19:41 | 显示全部楼层 |阅读模式
                                                终端点播发送数据,但是协调器接收不到,通过调试知道协调器(接收端)代码并未跑到AF_INCOMING_MSG_CMD事件中,发送数据的抓包截图显示数据已经发出去了,所以麻烦大佬帮我看一下咋回事吧,谢谢啦。
初始化部分代码:
SimpleDescriptionFormat_t zclGenericApp_SimpleDesc =
  GENERICAPP_ENDPOINT,                  //  int Endpoint;
  ZCL_HA_PROFILE_ID,                     //  uint16 AppProfId;
  // GENERICAPP_TODO: Replace ZCL_HA_DEVICEID_ON_OFF_LIGHT with application specific device ID
  ZCL_HA_DEVICEID_ON_OFF_LIGHT,          //  uint16 AppDeviceId;
  GENERICAPP_DEVICE_VERSION,            //  int   AppDevVer:4;
  GENERICAPP_FLAGS,                     //  int   AppFlags:4;
  ZCLGENERICAPP_MAX_INCLUSTERS,         //  byte  AppNumInClusters;
  (cId_t *)zclGenericApp_InClusterList, //  byte *pAppInClusterList;
  ZCLGENERICAPP_MAX_OUTCLUSTERS,        //  byte  AppNumInClusters;
  (cId_t *)zclGenericApp_OutClusterList //  byte *pAppInClusterList;
static endPointDesc_t zclGenericApp_TestEp =
GENERICAPP_ENDPOINT, // endpoint
0,
&zclGenericApp_TaskID,
(SimpleDescriptionFormat_t *)&zclGenericApp_SimpleDesc,
noLatencyReqs
14
const cId_t zclGenericApp_InClusterList[] =
  ZCL_CLUSTER_ID_GEN_BASIC,
  ZCL_CLUSTER_ID_GEN_IDENTIFY,
  ZCL_CLUSTER_CLUSTERID,
const cId_t zclGenericApp_OutClusterList[] =
发送部分代码:
my_DstAddr.addrMode = (afAddrMode_t)Addr16Bit;//设置发送模式
my_DstAddr.endPoint = GENERICAPP_ENDPOINT;//初始化端口号
my_DstAddr.addr.shortAddr=0x0000;
AF_DataRequest(&my_DstAddr,
   &zclGenericApp_TestEp,
   uart_rdlen-1,
   &uart_rdata[1],
   AF_DISCV_ROUTE,
   AF_DEFAULT_RADIUS);
接收部分代码:
14
15
16
17
18
19
case AF_INCOMING_MSG_CMD:
HalUARTWrite(0,"msg00\n",6);
GenericApp_MessageMSGCB( MSGpkt );
break;
void GenericApp_MessageMSGCB(afIncomingMSGPacket_t *pkt){
uint8 buffer[10];
switch ( pkt->clusterId )
case ZCL_CLUSTER_CLUSTERID:
osal_memcpy(buffer,pkt->cmd.Data,pkt->cmd.DataLength);
Uart_Write(SEND_DATA,0,buffer,pkt->cmd.DataLength);
break;
发送数据时抓包如下:
  •                                                 # Zigbee,zstack3.0.2, 2530
