海思 GPIO驱动程序
 楼主| 你画我瞎 发表于 2018-9-21 08:18 | 显示全部楼层 |阅读模式
#include <asm/io.h>
#include <mach/irqs.h>
#include <mach/hardware.h>
#define GPIO_DIR     0x400
#define GPIO_IS      0x404
#define GPIO_IBE     0x408
#define GPIO_IEV     0x40C
#define GPIO_IE      0x410
#define GPIO_RIS     0x414
#define GPIO_MIS     0x418
#define GPIO_IC      0x41C
/*                         gpio interface                               */
* _set_gpio_direction - set gpio direction
* @port:
* @offset:
* @dir: 0 -- input, 1 -- output
static void _set_gpio_direction(struct hisi_gpio_port *port, unsigned offset, int dir)
    u32 l;
    unsigned long flags;
    spin_lock_irqsave(&port->lock, flags);
    l = __raw_readl(port->base + GPIO_DIR);
    if (dir)
        l |= (1 << offset);
    else
        l &= ~(1 << offset);
    __raw_writel(l, port->base + GPIO_DIR);
    spin_unlock_irqrestore(&port->lock, flags);
* hisi_gpio_set - get gpio data
static void hisi_gpio_set(struct hisi_gpio_port *port, unsigned offset, int value)
    void __iomem *reg = port->base + (1 << (offset + 2));
    u32 l;
    l = (__raw_readl(reg) & (~(1 << offset))) | (!!value << offset);
    __raw_writel(l, reg);
* hisi_gpio_get - get gpio value
static int hisi_gpio_get(struct hisi_gpio_port *port, unsigned offset)
    u32 gpio_direction;
    gpio_direction = __raw_readl(port->base + GPIO_DIR);
    if (((gpio_direction >> offset) & 1))  /* output mode */
        return (__raw_readl(reg) >> offset) & 1;
    else /* input mode */
        return 0;
* hisi_gpio_direction_input - gpio direction input
static int hisi_gpio_direction_input(struct hisi_gpio_port *port, unsigned offset)
    _set_gpio_direction(port, offset, 0);
    return 0;
* hisi_gpio_direction_output - gpio direction output
static int hisi_gpio_direction_output(struct hisi_gpio_port *port, unsigned offset, int value)
    hisi_gpio_set(port, offset, value);
    _set_gpio_direction(port, offset, 1);
    return 0;
* hisi_gpio_init - gpio init functions
* @ int_trigger_type: 0~4, ref GT911 datasheet
* Must be called by goodix_ts_probe functions only once.
static int hisi_gpio_init(struct hisi_gpio_port *port, int int_trigger_type)
    int i, j;
    u32 l;
    unsigned offset;
    const uint8_t irq_table[] = GTP_IRQ_TAB;
    static bool initialed;
    if (initialed)
        return 0;
    printk(KERN_INFO "HISI GPIO hardware\n");
    /*1. ioremap */
    port->base = ioremap_nocache(GTP_BASE_ADDRESS, GTP_RANGE_SIZE);
    if (!port->base) {
        dev_err(&ts->client->dev,
            "Can't remap gpio address: 0x%x, size:0x%dx\n", GTP_BASE_ADDRESS, GTP_RANGE_SIZE);
        return -1;
    /*2. IOMUX */
    writel(reg, IOCONFIG_BASE + 0x178);
    writel(reg, IOCONFIG_BASE + 0x17C);
    /*3. config rest */
    offset = 7;
    hisi_gpio_direction_output(port, offset);  // output mode
    /*4. config int */
    offset = 6;
    hisi_gpio_direction_input(port, offset);  // input mode
    switch (irq_table[int_trigger_type])
    case IRQ_TYPE_EDGE_RISING:
                                 l = __raw_readl(port->base + GPIO_IS) & (~(1 << offset));
                                 __raw_writel(l, port->base + GPIO_IS);
                                 l = __raw_readl(port->base + GPIO_IEV) | (1 << offset);
                                 __raw_writel(l, port->base + GPIO_IEV);
                                 l = __raw_readl(port->base + GPIO_IBE) & (~(1 << offset));
                                 __raw_writel(l, port->base + GPIO_IBE);
        break;
    case IRQ_TYPE_EDGE_FALLING:
                                  l = __raw_readl(port->base + GPIO_IEV) & (~(1 << offset));
        break;
    case IRQ_TYPE_LEVEL_LOW:
                               l = __raw_readl(port->base + GPIO_IS) | (1 << offset);
        break;
    case IRQ_TYPE_LEVEL_HIGH:
        break;
    default:
        break;
    /* disable the interrupt and clear the status */
    __raw_writel(~0, port->base + GPIO_IC);
    __raw_writel(~0, port->base + GPIO_IE);
    spin_lock_init(&port->lock);
    initialed = true;
    return 0;
* hisi_gpio_deinit - DeInit functions
static void hisi_gpio_deinit(struct hisi_gpio_port *port)
    if (!port)
        return;
    __raw_writel(0, port->base + GPIO_IE);
    if (port->base)
        iounmap(port->base);
}  复制代码
