cdev_add alloc_chrdev_region 系列函数
 楼主| 石头张 发表于 2018-9-27 12:14 | 显示全部楼层 |阅读模式
在Linux 2.6内核中的字符设备用cdev结构来描述,其定义如下:
struct cdev  {     struct kobject kobj;     struct module *owner; //所属模块     const struct file_operations *ops; //文件操作结构     struct list_head list;     dev_t dev; //设备号,int 类型,高12位为主设备号,低20位为次设备号     unsigned int count; };
下面一组函数用来对cdev结构进行操作:struct cdev *cdev_alloc(void);//分配一个cdev void cdev_init(struct cdev *, const struct file_operations *);//初始化cdev的file_operation void cdev_put(struct cdev *p);// //减少使用计数 //注册设备,通常发生在驱动模块的加载函数中 int cdev_add(struct cdev *, dev_t, unsigned);  //注销设备,通常发生在驱动模块的卸载函数中 void cdev_del(struct cdev *);
使用cdev_add注册字符设备前应该先调用register_chrdev_region或alloc_chrdev_region分配设备号。register_chrdev_region函数用于指定设备号的情况,alloc_chrdev_region函数用于动态申请设备号,系统自动返回没有占用的设备号。
int register_chrdev_region(dev_t from, unsigned count, const char *name) ; int alloc_chrdev_region(dev_t *dev,unsigned baseminor,unsigned count,const char *name);
alloc_chrdev_region申请一个动态主设备号,并申请一系列次设备号。baseminor为起始次设备号,count为次设备号的数量。注销设备号(cdev_del)后使用unregister_chrdev_region:void unregister_chrdev_region(dev_t from,unsigned count) ;
cdev_add注册字符设备实例
struct file_operations simple_fops = {
    .owner =    THIS_MODULE,     .read =     simple_read,     .write =    simple_write,     .open =     simple_open,     .release =  simple_release, };  void simple_cleanup_module(void) {     dev_t devno = MKDEV(simple_MAJOR, simple_MINOR);     if (simple_devices)      {         cdev_del(&simple_devices->cdev);         kfree(simple_devices);     }     unregister_chrdev_region(devno,1); } //模块初始化 int simple_init_module(void) {     int result;     dev_t dev = 0;     dev = MKDEV(simple_MAJOR, simple_MINOR);     result = register_chrdev_region(dev, 1, "DEMO");//申请设备号     if (result <</SPAN> 0)      {         printk(KERN_WARNING "DEMO: can't get major %d\n", simple_MAJOR);         return result;     }     simple_devices = kmalloc(sizeof(struct simple_dev), GFP_KERNEL);     if (!simple_devices)     {         result = -ENOMEM;         goto fail;     }     memset(simple_devices, 0, sizeof(struct simple_dev));     //初始化设备结构     cdev_init(&simple_devices->cdev, &simple_fops);     simple_devices->cdev.owner = THIS_MODULE;     simple_devices->cdev.ops = &simple_fops;     result = cdev_add (&simple_devices->cdev, dev, 1);//添加字符设备     if(result)     {         printk(KERN_NOTICE "Error %d adding DEMO\n", result);         goto fail;     }     return 0; fail:     simple_cleanup_module();     return result; } module_init(simple_init_module); module_exit(simple_cleanup_module);
