ubuntu下的TCP网络编程框架
 楼主| roucun 发表于 2018-9-30 07:52 | 显示全部楼层 |阅读模式
  * @file    main.c
  * @author  Wang
  * @version V1.0.0
  * @date    9-August-2019
  * @brief   This file  call to function in other files
/* Includes ------------------------------------------------------------------*/
#include <stdio.h>
#include <sys/types.h>
#include <arpa/inet.h>
#include <string.h>
#include <sys/socket.h>
#include <netinet/in.h>
#include <unistd.h>
#include <stdlib.h>
  * @brief  main entry point
  * @param  argc : the number of param
  * @param  **argv : command-line pass arguments
  * @retval return 0
int main(int argc , const char **argv)
        int socket_fd;
        struct sockaddr_in server_addr;
        char buf[100] = {0};
        int n = 0 , len = sizeof(server_addr);
        if(argc != 3)
                printf("Usage : %s ip port \n",argv[0]);
                return -1;
        /*   use socket() obtain  sock_fd */
        socket_fd  = socket(AF_INET , SOCK_STREAM , 0);
        if(socket_fd < 0)
                perror("Fail to socket");
        /* Fill the information about server */
        server_addr.sin_family = AF_INET;
        server_addr.sin_port = htons(atoi(argv[2]));
        server_addr.sin_addr.s_addr = inet_addr(argv[1]);
        /* request connect server */
        if((connect(socket_fd , (struct sockaddr *)&server_addr , len)) < 0)
                perror("Fail to connect");
                return -1;
        printf("Please input data:\n");
        while(1)
                memset(buf , 0 , sizeof(buf));
                fgets(buf,sizeof(buf),stdin);
                buf[strlen(buf) - 1] = '\0';
                n = send (socket_fd , buf , strlen(buf) , 0);
                if(n < 0)
                        perror("Fail to send");
                        return -1;
                if(strncmp(buf , "quit" , 4) == 0)
                        break;
                printf("send %d bytes : %s\n",n,buf);
        close(socket_fd);
        return 0;
/**************************************END OF FILE**************************************/
复制代码
