错误一:
启动heartbeat服务室,出现以下错误:
a
根据提示信息在对文件进行排查后,发现问题:
主要是三个文件:
authkeys
ha.cf
haresources
在ha.cf中发现其中部分ucast部分的ip和真实配置的ip有误
如图:
其中对应的ip应为:192.168.170.132. 重新跟正后,问题得到解决,!!
错误二:
报错信息如下:
Dec 25 21:16:53 aming heartbeat:[4063]: ERROR: Client child command [/usr/lib/heartbeat/ipfail] isnot executable
Dec 25 21:16:53 aming heartbeat: [4063]: ERROR: Heartbeat notstarted: configuration error.
Dec 25 21:16:53 aming heartbeat: [4063]: ERROR: Configurationerror, heartbeat not started.
Dec 25 21:23:49 aming heartbeat: [4210]: ERROR: Client childcommand [/usr/lib/heartbeat/ipfail] is not executable
Dec 25 21:23:49 aming heartbeat: [4210]: ERROR: Heartbeat notstarted: configuration error.
Dec 25 21:23:49 aming heartbeat: [4210]: ERROR: Configurationerror, heartbeat not started.
Dec 25 21:24:20 aming heartbeat: [4350]: ERROR: Client childcommand [/usr/lib/heartbeat/ipfail] is not executable
Dec 25 21:24:20 aming heartbeat: [4350]: ERROR: Heartbeat notstarted: configuration error.
解决方法是:
因为报错是/usr/lib下面没有heartbeat这个目录,我的系统是64位的,所以在lib64下面,修改ha.cf的配置文件最后一样修改为respawnhacluster /usr/lib64/heartbeat/ipfail,再次启动服务就可以了。 |
