V4L2摄像头驱动及程序代码 GEC6818开发板
 楼主| 过期账户 发表于 2018-10-6 08:10 | 显示全部楼层 |阅读模式
这个代码实测可用于GEC6818的开发板
单片机源程序如下:
#include <stdio.h>
#include <sys/types.h>
#include <sys/stat.h>
#include <fcntl.h>
#include <unistd.h>
#include <sys/mman.h>
#include <linux/input.h>
#include <strings.h>
#include "jpeglib.h"
#include "api_v4l2.h"
#include <stdlib.h>
#include <pthread.h>
#define LCD_WIDTH 800
#define LCD_HEIGHT 480
int *p = NULL;
int lcd_fd = -1;
int is_open_camera = 0;
int is_video_play = 0;
int is_vedio_record = 0;
int video_count=1;
FrameBuffer camera_buf;
int video_fd;
char bmp[3][10] =
        "1.bmp",
        "2.bmp",
        "girl.bmp"
int lcd_open(void)
        lcd_fd = open("/dev/fb0",O_RDWR);
        if(lcd_fd < 0)
                perror("lcd open failed");
                return 0;
        p = mmap(NULL, LCD_WIDTH*LCD_HEIGHT*4,
                        PROT_READ | PROT_WRITE,
                        MAP_SHARED,
                        lcd_fd,
                        0);
        if (NULL == p)
                perror("lcd mmap error: ");
                return -1;
        return 0;
int lcd_draw_point(int x, int y, int color)
        if (x > 800)
                printf("value of X-coordinates is over: %d\n", LCD_WIDTH);
                return -1;
        if (y > 480)
                printf("value of Y-coordinates is over: %d\n", LCD_HEIGHT);
                return -1;
        *(p + x + y*800) = color;
        return 0;
void lcd_draw_bmp(const char *file_name, int x0, int y0)
        int fd;
        int bmp_width;
        int bmp_height;
        char buf[54];
        fd = open(file_name, O_RDONLY);
        if (fd < 0)
                perror("open file error: ");
                return ;
                /* 读取位图头部信息 */
        read(fd,buf,54);
        /* 宽度  */
        bmp_width =buf[18];
        bmp_width|=buf[19]<<8;
        //printf("bmp_width=%d\r\n",bmp_width);
        /* 高度  */
        bmp_height =buf[22];
        bmp_height|=buf[23]<<8;
        //printf("bmp_height=%d\r\n",bmp_height);
        int len;
        len = bmp_width*bmp_height*3;
        //跳过 前边54个字节,这54个字节是用来存储bmp图片的相关信息的
        lseek(fd, 54, SEEK_SET);
        //从第55个字节开始,读取bmp图片的像素数组
        char bmp_buf[len];
        read(fd, bmp_buf, len);//因为这个bmp图片是24位色
        close(fd);
        int color, x, y, i = 0;
        unsigned char r, g, b;
        for (y = 0; y < bmp_height; y++)
                for (x = 0; x < bmp_width; x++)
                        //将一个24bit //bmp图片的像素点转换为LCD的一个像素点
                        b = bmp_buf[i++];
                        g = bmp_buf[i++];
                        r = bmp_buf[i++];
                        color = (r << 16) | (g << 8) | b;
                        lcd_draw_point(x + x0, bmp_height-y+y0-1, color);
int get_pos(int *pos_x,int *pos_y)
        // 打开触摸屏设备
        struct input_event buf;
        bzero(&buf, sizeof(buf));
        int ts = open("/dev/input/event0", O_RDONLY);
        if(ts < 0)
                perror("open touch srceen failed");
                return -1;
        while(1)
                // 循环地读取触摸屏信息
                read(ts, &buf, sizeof(buf));
                // 遇到 X轴 坐标事件
                if(buf.type == EV_ABS && buf.code == ABS_X)
                        *pos_x = buf.value;
                        printf("(%d, ", *pos_x);
                // 遇到 Y轴 坐标事件
                if(buf.type == EV_ABS && buf.code == ABS_Y)
                        *pos_y = buf.value;
                        printf("%d)\n", *pos_y);
                //判断手指松开
                if (buf.value == 0)
                        break;
*函数名称:file_size_get
*输入参数:pfile_path        -文件路径
*返 回 值:-1                -失败
                   其他值        -文件大小
*说        明:获取文件大小
unsigned long file_size_get(const char *pfile_path)
        unsigned long filesize = -1;
        struct stat statbuff;
        if(stat(pfile_path, &statbuff) < 0)
                return filesize;
        else
                filesize = statbuff.st_size;
        return filesize;
x                        :起点
y                        :起点
pjpg_path        :图片路径
pjpg_buf    :摄像头获取的图像数据,如果你没用摄像头一般设为NULL
jpg_buf_size:摄像头数据的大小,默认设为0
int lcd_draw_jpg(unsigned int x,unsigned int y,const char *pjpg_path,char *pjpg_buf,unsigned int jpg_buf_size)
        /*定义解码对象,错误处理对象*/
        struct         jpeg_decompress_struct         cinfo;
        struct         jpeg_error_mgr                         jerr;
        char         g_color_buf[800*480*4];
        char         *pcolor_buf = g_color_buf;
        char         *pjpg;
        unsigned int         i=0;
        unsigned int        color =0;
        unsigned int        count =0;
        unsigned int         x_s = x;
        unsigned int         x_e ;
        unsigned int         y_e ;
                         int        jpg_fd;
        unsigned int         jpg_size;
        unsigned int         jpg_width;
        unsigned int         jpg_height;
        if(pjpg_path!=NULL)
                /* 申请jpg资源,权限可读可写 */
                jpg_fd=open(pjpg_path,O_RDWR);
                if(jpg_fd == -1)
                   printf("open %s error\n",pjpg_path);
                   return -1;
…………限于本文篇幅 余下代码请从51黑下载附件…………
复制代码
所有资料51hei提供下载:
code.7z
(418.64 KB, 下载次数: 0)
2020-7-30 13:38 上传
点击文件名下载附件
下载积分: 黑币 -5
