// CONFIG1
#pragma config FEXTOSC = OFF // FEXTOSC External Oscillator mode Selection bits->Oscillator not enabled
#pragma config RSTOSC = HFINT1 // Power-up default value for COSC bits->HFINTOSC (1MHz)
#pragma config CLKOUTEN = OFF // Clock Out Enable bit->CLKOUT function is disabled; I/O or oscillator function on OSC2
#pragma config CSWEN = ON // Clock Switch Enable bit->Writing to NOSC and NDIV is allowed
#pragma config FCMEN = ON // Fail-Safe Clock Monitor Enable->Fail-Safe Clock Monitor is enabled
// CONFIG2
#pragma config MCLRE = ON // Master Clear Enable bit->MCLR/VPP pin function is MCLR; Weak pull-up enabled
#pragma config PWRTE = ON // Power-up Timer Enable bit->PWRT enabled
#pragma config WDTE = SWDTEN // Watchdog Timer Enable bits->WDT controlled by the SWDTEN bit in the WDTCON register
#pragma config LPBOREN = OFF // Low-power BOR enable bit->ULPBOR disabled
#pragma config BOREN = OFF // Brown-out Reset Enable bits->Brown-out Reset enabled, SBOREN bit ignored
#pragma config BORV = LOW // Brown-out Reset Voltage selection bit->Brown-out voltage (Vbor) set to 2.45V
#pragma config PPS1WAY = ON // PPSLOCK bit One-Way Set Enable bit->The PPSLOCK bit can be cleared and set only once; PPS registers remain locked after one clear/set cycle
#pragma config STVREN = ON // Stack Overflow/Underflow Reset Enable bit->Stack Overflow or Underflow will cause a Reset
#pragma config DEBUG = OFF // Debugger enable bit->Background debugger disabled
// CONFIG3
#pragma config WRT = OFF // User NVM self-write protection bits->Write protection off
#pragma config LVP = ON // Low Voltage Programming Enable bit->Low Voltage programming enabled. MCLR/VPP pin function is MCLR. MCLRE configuration bit is ignored.
// CONFIG4
#pragma config CP = OFF // User NVM Program Memory Code Protection bit->User NVM code protection disabled
#pragma config CPD = OFF // Data NVM Memory Code Protection bit->Data NVM code protection disabled
// CONFIG1
// CONFIG2
#pragma config PWRTE = OFF // Power-up Timer Enable bit->PWRT disabled
#pragma config WDTE = OFF // Watchdog Timer Enable bits->WDT disabled; SWDTEN is ignored
#pragma config BOREN = OFF // Brown-out Reset Enable bits->Brown-out Reset disabled
#pragma config PPS1WAY = OFF // PPSLOCK bit One-Way Set Enable bit->The PPSLOCK bit can be set and cleared repeatedly (subject to the unlock sequence)
// CONFIG3
#pragma config LVP = OFF // Low Voltage Programming Enable bit->High Voltage on MCLR/VPP must be used for programming.
// CONFIG4
