[软件] RK3399点LVDS屏软硬件实现流程
 楼主| qq7643066 发表于 2020-10-16 17:38 | 显示全部楼层 |阅读模式
RK3399本身不带LVDS输出,rk3288就有各种接口,差!!!!
可是他的性能强啊,我们还是分析怎么实现。
实现框架:
原理图:
8775芯片电路
8775供电
lvds标准接口
看到了吧,硬件如此简单。
软件有点麻烦了。
要弄一推补丁
修个各种mipi指令、gpio,调VOB通道等等
dts配置
        panel: panel {
                compatible= "simple-panel";
                backlight= <&backlight>;
                power-supply= <&vcc_lcd>;
                enable-gpios= <&gpio1 13 GPIO_ACTIVE_HIGH>;
                prepare-delay-ms= <20>;
                enable-delay-ms= <20>;
                display-timings{
                        native-mode= <&timing0>;
                        timing0: timing0 {
                                clock-frequency= <200000000>;
                                hactive= <1920>;//1536
                                vactive= <1080>;//2048
                                hfront-porch= <12>;
                                hsync-len= <16>;
                                hback-porch= <48>;
                                vfront-porch= <8>;
                                vsync-len= <4>;
                                vback-porch= <8>;
                                hsync-active= <0>;
                                vsync-active= <0>;
                                de-active = <0>;
              pixelclk-active =<0>;
&dsi {
        status ="okay";
        rockchip,lane-rate= <900>;
        panel@0 {
                //status= "okay";
                compatible="simple-panel-dsi";
                reg= <0>;
                //power-supply= <&vcc_lcd>;
                enable-gpios= <&gpio3 16 GPIO_ACTIVE_HIGH>;
                //enable-gpios= <&gpio2 9  GPIO_ACTIVE_HIGH>;// tc35 stby 2_b1
         reset-gpios = <&gpio2 27GPIO_ACTIVE_LOW>;
                dsi,flags= <(MIPI_DSI_MODE_VIDEO | MIPI_DSI_MODE_VIDEO_BURST |
                              MIPI_DSI_MODE_LPM |MIPI_DSI_MODE_EOT_PACKET)>;
                dsi,format= <MIPI_DSI_FMT_RGB888>;
                dsi,lanes= <4>;
            enable-delay-ms = <35>;
       prepare-delay-ms = <6>;
        delay,power= <10>;
        delay,reset= <20>;
       unprepare-delay-ms = <0>;
       disable-delay-ms = <20>;
        size,width= <120>;
        size,height = <170>;
       status = "okay";
                        timing1: timing1 {
                                clock-frequency= <148500000>;
                                hactive= <1920>;
                                vactive= <1080>;
                                hback-porch = <100>;
                                hsync-len= <20>;
                                hfront-porch= <160>;
                                vback-porch= <25>;
                                vfront-porch= <10>;
                                vsync-len= <10>;
                                hsync-active= <0>;
                                vsync-active= <0>;
                                de-active = <0>;
结果终于搞定
dufanghua 发表于 2020-10-22 14:22 | 显示全部楼层
支持下
个人签名:承接MID、Android TV等项目定制 QQ:7643066
98
98
