//定时器2通道2输入捕获配置
TIM_ICInitTypeDef TIM2_ICInitStructure;
void TIM2_Cap_Init(u16 arr,u16 psc)
TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
NVIC_InitTypeDef NVIC_InitStructure;
TIM_DeInit(TIM2);
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE); //使能TIM2时钟
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE); //使能GPIOB时钟
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0; //PB0 清除之前设置
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPD; //PB0 输入
GPIO_Init(GPIOB, &GPIO_InitStructure);
GPIO_ResetBits(GPIOB,GPIO_Pin_0); //PB0 下拉
//初始化定时器2 TIM2
TIM_TimeBaseStructure.TIM_Period = arr; //设定计数器自动重装值
TIM_TimeBaseStructure.TIM_Prescaler =psc; //预分频器
TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1; //设置时钟分割:TDTS = Tck_tim
TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up; //TIM向上计数模式
TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure); //根据TIM_TimeBaseInitStruct中指定的参数初始化TIMx的时间基数单位
//初始化TIM2输入捕获参数
TIM2_ICInitStructure.TIM_Channel = TIM_Channel_2; //CC1S=01 选择输入端 IC1映射到TI1上
TIM2_ICInitStructure.TIM_ICPolarity = TIM_ICPolarity_Rising; //上升沿捕获
TIM2_ICInitStructure.TIM_ICSelection = TIM_ICSelection_DirectTI; //映射到TI1上
TIM2_ICInitStructure.TIM_ICPrescaler = TIM_ICPSC_DIV1; //配置输入分频,不分频
TIM2_ICInitStructure.TIM_ICFilter = 0x00;//IC1F=0000 配置输入滤波器 不滤波
TIM_ICInit(TIM2, &TIM2_ICInitStructure);
//中断分组初始化
NVIC_InitStructure.NVIC_IRQChannel = TIM2_IRQn; //TIM2中断
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0; //先占优先级2级
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 2; //从优先级0级
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; //IRQ通道被使能
NVIC_Init(&NVIC_InitStructure); //根据NVIC_InitStruct中指定的参数初始化外设NVIC寄存器
// TIM_ARRPreloadConfig(TIM2, ENABLE);
// TIM_ClearITPendingBit(TIM2, TIM_IT_CC2); //清除中断标志位
// TIM_ITConfig(TIM2,TIM_IT_CC2,ENABLE); //使能CC1IE捕获中断
// TIM_Cmd(TIM2,ENABLE ); //使能定时器2
//u8 TIM2CH2_CAPTURE_STA=0; //输入捕获状态
//u16 TIM2CH2_CAPTURE_VAL; //输入捕获值
u16 COUNT;
u16 C_FLAG;
//定时器2中断服务程序
void TIM2_IRQHandler(void)
u16 IC2Value;
if (TIM_GetITStatus(TIM2, TIM_IT_CC2) != RESET)//捕获1发生捕获事件
COUNT++;
TIM2->SR &= ~0x0404; //软件清除CC2IF和CC2OF标志
IC2Value = TIM_GetCapture2(TIM2);
printf("IC2Value:%d摄氏度\n",IC2Value);
C_FLAG=1;
