[MCU] 原子操作
 楼主| liliang9554 发表于 2020-12-14 23:37 | 显示全部楼层 |阅读模式
用TIME0循环读四路风扇转速,是直接用time0来计算脉宽,我是循环开中断来做的,
(TA0CCTL1&= ~CCIE;  TA0CCTL2|= CCIE;)-->(TA0CCTL2&= ~CCIE;  TA0CCTL3|= CCIE;)......
(TA0CCTL4&= ~CCIE;  TA0CCTL1|= CCIE;)
在中断里面关掉自己中断的使能和 TA0CTL|=TACLR;有没有潜在的危险?
char  fan_times_tmp = 0;                   //用来记录次数的中间变量
char  fan_flag = 0;                        //进入中断标志位
#pragma vector=TIMER0_A1_VECTOR
//__interrupt void TIMER0_A1_ISR(void)
__interrupt void TIMER0_A(void)
  switch(TA0IV)
    case  0: break;                             // No interrupt
    case  2:
            if((TA0CCTL1&CM_2)&&(fan_flag == 0))
            {                                   //清计数器
              TA0CTL|=TACLR;
              fan_flag = 1;
              P3OUT ^= BIT2;
           else if((TA0CCTL1&CM_2)&&(fan_flag == 1))
             speed_tmp[fan_times_tmp++] = TA0CCR1;
              fan_flag = 0;
              if(fan_times_tmp == fan_data_time)
                 fan_a = 0;
                 for(fan_i=0;fan_i<fan_data_time;fan_i++)
                 fan_a +=speed_tmp[fan_i];
                 fan_a >>= 5;              //除以4求平均值,以免数据不停跳变
                 fan_speed[0] = fan_a;
                 fan_i = 0;
              //   TA0CCTL1&= ~CCIE;
              //   TA0CCTL2|= CCIE;
                 fan_times_tmp = 0;
      TA0CCTL1 &= ~CCIFG; break;
                break;                          // CCR1 not used
    case  4:
      if((TA0CCTL2&CM_2)&&(fan_flag == 0))
            {                                   //清计数器
              TA0CTL|=TACLR;
              fan_flag = 1;
           else if((TA0CCTL2&CM_2)&&(fan_flag == 1))
              speed_tmp[fan_times_tmp++] = TA0CCR2;
              fan_flag = 0;
                 fan_a = 0;
                 fan_i = 0;
                 TA0CCTL2&= ~CCIE;
                 TA0CCTL3|= CCIE;
                 fan_times_tmp = 0;
      TA0CCTL2 &= ~CCIFG;
      break;
      break;            // CCR2 not used
    case  6:
      if((TA0CCTL3&CM_2)&&(fan_flag == 0))
            {                                   //清计数器
              TA0CTL|=TACLR;
              fan_flag = 1;
           else if((TA0CCTL3&CM_2)&&(fan_flag == 1))
              speed_tmp[fan_times_tmp++] = TA0CCR3;
              fan_flag = 0;
                 fan_a = 0;
                 fan_i = 0;
                 TA0CCTL3&= ~CCIE;
                 TA0CCTL1|= CCIE;
                 fan_times_tmp = 0;
      TA0CCTL3 &= ~CCIFG;
      break;         // reserved
    case  8:
      if((TA0CCTL4&CM_2)&&(fan_flag == 0))
            {                                   //清计数器
              TA0CTL|=TACLR;
              fan_flag = 1;
           else if((TA0CCTL4&CM_2)&&(fan_flag == 1))
              speed_tmp[fan_times_tmp++] = TA0CCR4;
              fan_flag = 0;
                 fan_a = 0;
                 fan_i = 0;
                 TA0CCTL4&= ~CCIE;
                 TA0CCTL1|= CCIE;
                 fan_times_tmp = 0;
      TA0CCTL4 &= ~CCIFG;
      break;         // reserved
    case 10:                           // reserved
    case 12:                         // reserved
    case 14: //TA1CCTL1 &= ~COV;                  // overflow
      break;
    default:break;
 楼主| liliang9554 发表于 2020-12-14 23:40 | 显示全部楼层
另外我程序用也开了time1做轮询中断,因为mian函数中和轮询中断中存在这共同的全局变量,所以mian函数中在读写这个全局变量的时候要先关掉轮询中断,现在不清楚TA2CCTL1 &= ~CCIE; 存在不存在原子操作的说法
zhanghqi 发表于 2020-12-14 23:45 | 显示全部楼层
会不会在执行TA2CCTL1 &= ~CCIE;被中断硬件修改CCIFG位造成不可预知的情况?
 楼主| liliang9554 发表于 2020-12-14 23:48 | 显示全部楼层
while(1)
    while(1)                   //关机
        // while (!(UCA0IFG&UCTXIFG));
        //           UCA0TXBUF = 1;
      PWM_CTRL(1,1);
      TA2CCTL1 &= ~CCIE;                      //关轮询中断(避免 cpu_stat  ***FLAG
                                              //在轮询中断中发生改变 )
      if( cpu_stat == CPU_POWER_DOWN )
          if(1 == power_down_flag)
            power_down_flag = 0;
            power_on_flag = 1;
          TA2CCTL1 |= CCIE;                      //开轮询中断
      else
          TA2CCTL1 |= CCIE;
        break;
#pragma vector=TIMER2_A1_VECTOR
__interrupt void TIMER2_A1_ISR(void)
  switch( __even_in_range(TA2IV,14))
    case 0: break;
    case 2:
      P3OUT ^=0X01;
      TA2CCR1 += 0X4E2;                  //按键检测 每5ms检测一次
gongche 发表于 2020-12-14 23:51 | 显示全部楼层
求430汇编高手解答。
wuhany 发表于 2020-12-14 23:54 | 显示全部楼层
:L这和汇编有啥关系?
 楼主| liliang9554 发表于 2020-12-14 23:58 | 显示全部楼层
最近公司一个做C++的同事看了,mian函数+中断类似多线程,并且存在着共同的全局变量,需要对全局变量("加锁")保护,现在思维乱了,分不清关CCIE存在不存在原子操作的说法
需要把每一步C分解成汇编来考虑这个问题,思维乱了。
fuqinyyy 发表于 2020-12-15 07:14 来自手机 | 显示全部楼层
C和C++严谨程度不一样
 楼主| liliang9554 发表于 2020-12-15 18:48 | 显示全部楼层
恩恩,这个东西只能看汇编,才能清楚
wyjie 发表于 2020-12-15 18:52 | 显示全部楼层
测脉宽用“捕足”不行吗?
 楼主| liliang9554 发表于 2020-12-15 18:56 | 显示全部楼层
捕足?不理解 请简单说一下吧,谢谢
dengdc 发表于 2020-12-15 19:00 | 显示全部楼层
测脉宽可以用外部中断捕获上下沿的时间点来计算出来
 楼主| liliang9554 发表于 2020-12-15 19:03 | 显示全部楼层
case  2:
            {                                   //清计数器
              TA0CTL|=TACLR;
              fan_flag = 1;
              P3OUT ^= BIT2;
              fan_flag = 0;
                 fan_a = 0;
                 fan_i = 0;
/***********************在中断中关闭这个使能会有影响吗?*******************************/
               TA0CCTL1&= ~CCIE;
               TA0CCTL2|= CCIE;
zhanghqi 发表于 2020-12-15 19:07 | 显示全部楼层
楼主的这个问题其实是中断的优先级问题以及中断嵌套问题。
dengdc 发表于 2020-12-15 19:12 | 显示全部楼层
msp430默认的是关闭中断嵌套的,除非你在一个中断程序中再次开总中断EINT。
jiahy 发表于 2020-12-15 19:15 | 显示全部楼层
所以楼主在中断中关闭这个中断的使能,是不会被打断的,所以不会有风险。
 楼主| liliang9554 发表于 2020-12-15 19:18 | 显示全部楼层
嗯,我知道了,多谢
