[以太网/USB/其他总线] LAN9252&LAN9253 EtherCAT Module
 楼主| zbh2012 发表于 2021-1-28 00:15 | 显示全部楼层 |阅读模式
LAN9252&LAN9253模块,SPI转EtherCAT module 参考设计+源码+技术支持,有需求的留言我。QQ:1048643578
提供完整解决方案。SPI转EtherCAT小模块,源代码+参考设计+技术支持,需要的请留言!
LAN9252/3 is a 2/3-port EtherCAT slave controller with 3 Fieldbus Memory Management Units (FMMUs) and 4 SyncManagers
• Interfaces to most 8/16-bit embedded controllers and 32-bit embedded controllers with an 8/16-bit bus
• Integrated Ethernet PHYs with HP Auto-MDIX
• Wake on LAN (WoL) support
• Low power mode allows systems to enter sleep mode until addressed by the Master
• Cable diagnostic support
• 1.8V to 3.3V variable voltage I/O
• Integrated 1.2V regulator for single 3.3V operation
• Low pin count and small body size package
luospring123 发表于 2025-6-15 21:20 | 显示全部楼层
买芯片可以找您不?哈哈
