[ZLG-ARM] LPC2368 ADS环境下,这种报错改如何解决啊
 楼主| mtraveler 发表于 2012-2-24 14:00 | 显示全部楼层 |阅读模式
file:///C:/Documents%20and%20Settings/Administrator/Application%20Data/Tencent/Users/410827132/QQ/WinTemp/RichOle/LVVEKJK1@}@2Q~CWLGT6WMB.jpg
Error   : L6200E: Symbol _sys_close multiply defined (by sys_io.o and target.o).
Error   : L6200E: Symbol _sys_write multiply defined (by sys_io.o and target.o).
Error   : L6200E: Symbol _sys_read multiply defined (by sys_io.o and target.o).
Error   : L6200E: Symbol _sys_istty multiply defined (by sys_io.o and target.o).
Error   : L6200E: Symbol _sys_seek multiply defined (by sys_io.o and target.o).
Error   : L6200E: Symbol _sys_ensure multiply defined (by sys_io.o and target.o).
Error   : L6200E: Symbol _sys_flen multiply defined (by sys_io.o and target.o).
Error   : L6200E: Symbol __semihosting_swi_guard multiply defined (by use_semi.o and use_no_semi.o).
之前看了一些帖子说是因为SEMIHOSTING,禁用了,但仍然使用了所以报错,改如何解决啊?网上有讨论的,单都没有给出解决方法
 楼主| mtraveler 发表于 2012-2-25 10:46 | 显示全部楼层
汗,又是自己,解决方法:删掉掉或重写semihosting机制调用的函数
tylhc002 发表于 2012-2-25 14:43 | 显示全部楼层
1# mtraveler
