PFC886+互补6pwm
 楼主| 34af9uc 发表于 2021-3-22 12:45 | 显示全部楼层 |阅读模式
/******************************************PFC886+互补6pwm*******************************************/
/******************************************QQ:774145445**********************************************/
/******************************************快手:共同学习STM8*****************************************/
//                     __________@__________
//              PWM2L-|1 pa2          pa1 20|-PWM2H
//              PWM1L-|2 pa3          pa0 19|-PWM1H
//              pwm0L-|3 pa4          pa7 18|-pwm0H
//                    |4 pa5          pa6 17|
//                    |5 nc            nc 16|
//                    |6 gnd          vdd 15|
//                 k1-|7 pb0          pb7 14|
//                 k2-|8 pb1          pb6 13|
//                 k3-|9 pb2          pb5 12|
//                 k4-|10_pb3_________pb4_11|
#include        "extern.h"
k1                bit                pb.0;
k2                bit                pb.1
k3                bit                pb.2
k4                bit                pb.3
void                zhengxian();                //正弦
void                yanshi();                        //延时
word                a1,a2,a3;
void        FPPA0 (void)
.ADJUST_IC        SYSCLK=IHRC/4                //        SYSCLK=IHRC/4
//byte                a1,a2,a3;
a1                        =0;
a2                        =255;
pmode                31;                        ///8/8/8/8/8/8/8/8带宽共享
fppen        =        0xFF;                //8核全开
//有8个核心可以分时全部运行,可以分别干8件事8核真爽!
//$                pwmgc                enable,updown,reset;
//$                pwmgm                protection_enable,ihrc,/16;
pwmgc                =0b1_0_1_1_0000;                //PWMG控制寄存器
//7,停用启用6,输出状态5,中心排列模式4,PWM计数器清零
//pwmgm                =0b0_0_1_0_10_10;                //PWMG分频寄存器
pwmgm                =0b0_0_1_0_10_11;                //PWMG分频寄存器
//7,上臂反极性6,下臂反极性5,臂保护4,臂保护模式32,PWM时钟源10,PWM分频
pwmgc1                =0b1_11_0_01_10;                //PWMG控制寄存器1
//7,互补发生器65,三相电机4,读零32,PWM5.PWM+|10,PWM4.PWM-
pwmgc2                =0b01_10_01_10;                //PWMG控制寄存器2
//76,PWM3.PWM+|54,PWM2.PWM-|32,PWM1.PWM+|10,PWM0.PWM-
pwmcubl                =0b1111_0000;                //pwm上限寄存器l
pwmcubh                =0b1111_1111;                //pwm上限寄存器h
pwmdz                =0b1111_0000;                //死区寄存器
//pwm0dtl                =0b1111_0000;                //pwm0占空比低位寄存器//先写低位
//pwm0dth                =0b1111_1111;                //pwm0占空比高位寄存器
//pwm1dtl                =0b0000_0000;                //pwm1占空比低位寄存器//先写低位
//pwm1dth                =0b1000_0000;                //pwm1占空比高位寄存器
//pwm2dtl                =0b1111_0000;                //pwm2占空比低位寄存器//先写低位
//pwm2dth                =0b0000_0000;                //pwm2占空比高位寄存器
$                k1                in,pull;                //输入上拉电阻
$                k2                in,pull;
$                k3                in,pull;
$                k4                in,pull;
a1                =0;
a2                =511;
a3                =1;
while (1)
//.delay                400000;
//anjian();
void        FPPA1 (void)
//        goto        $;
pwm0dtl                =0;
//pwm0dth                =a1;
pwm1dtl                =0;
pwm1dth                =a2;
pwm2dtl                =0;
pwm2dth                =a3;
        while (1)
zhengxian();
void        FPPA2 (void)
        goto        $;
void        FPPA3 (void)
        goto        $;
void        FPPA4 (void)
        goto        $;
void        FPPA5 (void)
        goto        $;
void        FPPA6 (void)
        goto        $;
void        FPPA7 (void)
        goto        $;
void        Interrupt (void)
        pushaf;
        if (Intrq.T16)
        {        //        T16 Trig
                //        User can add code
                Intrq.T16        =        0;
        popaf;
void                zhengxian()                //正弦
pwm0dth                =0x31;
yanshi();
pwm0dth                =0x61;
yanshi();
pwm0dth                =0x8E;
yanshi();
pwm0dth                =0xB5;
yanshi();
pwm0dth                =0xD4;
yanshi();
pwm0dth                =0xEC;
yanshi();
pwm0dth                =0xD4;
yanshi();
pwm0dth                =0xB5;
yanshi();
pwm0dth                =0x8E;
yanshi();
pwm0dth                =0x61;
yanshi();
void                yanshi()                        //延时
.delay                1000;
/*if(k1)
nop;
nop;
while(k1){.delay 100;}                //定在这
while(!k1){.delay 100;}                //等待松手
pwm01.rar
1.35 KB, 下载次数: 10
spwmsc(www.greenxf.com).zip
443.92 KB, 下载次数: 16
