您好,我现在用航顺的HK32f103cbt6遇到了ADC不能用的情况,卡在了校准这里,while(ADC_GetCalibrationStatus(ADCx)); 在stm32上面是正常使用的,代码如下
- #include "power-adc.h"
- #define USED_ADC1 ADC1
- #define USED_ADC_RCC RCC_APB2Periph_ADC1
- #define USED_ADC_GPIO_RCC RCC_APB2Periph_GPIOA
- #define USED_ADC_PORT GPIOA
- #define USED_ADC_PIN GPIO_Pin_4
- #define USED_ADC_CHANNEL ADC_Channel_4
- float voltage;
- //ADC时钟开启
- void ADC_RCC_Configuration(void)
- RCC_APB2PeriphClockCmd(USED_ADC_GPIO_RCC | USED_ADC_RCC, ENABLE);
- RCC_ADCCLKConfig(RCC_PCLK2_Div6);
- //ADC GPIO设置
- void ADC_GPIO_Config(void)
- GPIO_InitTypeDef GPIO_InitStructure;
- GPIO_InitStructure.GPIO_Pin = USED_ADC_PIN;
- //GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;
- GPIO_Init(USED_ADC_PORT,&GPIO_InitStructure);
- //ADC 设置
- void ADC_Config(ADC_TypeDef* ADCx,uint8_t ADC_Channel)
- ADC_InitTypeDef ADC_InitStructure;
- //ADC_StructInit(&ADC_InitStructure);
- ADC_DeInit(ADCx);
- ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;
- ADC_InitStructure.ADC_ScanConvMode =DISABLE;
- ADC_InitStructure.ADC_ContinuousConvMode = DISABLE ;
- ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;
- ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
- ADC_InitStructure.ADC_NbrOfChannel = 1;
- ADC_Init(ADCx,&ADC_InitStructure);
- DELAY_SOME(10);
- ADC_RegularChannelConfig(ADCx, ADC_Channel, 1, ADC_SampleTime_239Cycles5 );
- DELAY_SOME(10);
- ADC_Cmd(ADCx, ENABLE);
- DELAY_SOME(10);
- ADC_ResetCalibration(ADCx);
- while(ADC_GetResetCalibrationStatus(ADCx));
- DELAY_SOME(10);
- ADC_StartCalibration(ADCx);
- while(ADC_GetCalibrationStatus(ADCx));
- //初始化ADC
- void ADC_INIT()
- //ADC时钟开启
- ADC_RCC_Configuration();
- //ADC GPIO设置
- ADC_GPIO_Config();
- //ADC 设置
- ADC_Config(USED_ADC1,USED_ADC_CHANNEL);
- //获取ADC的值
- void get_ADC_Value()
- ADC_ClearFlag(USED_ADC1,ADC_FLAG_EOC);
- ADC_SoftwareStartConvCmd(USED_ADC1, ENABLE);//开启ADC
- DELAY_SOME(10);
- while(RESET == ADC_GetFlagStatus(USED_ADC1,ADC_FLAG_EOC));
- voltage = 3.3*ADC_GetConversionValue(USED_ADC1)/4096;
- ADC_SoftwareStartConvCmd(USED_ADC1, DISABLE);//关闭ADC
复制代码
