No. | | Philippine National Standard/s (PNS) | | | Pre-heat / Magnetic ballasts 预热/电磁镇流器 | PNS IEC 61347-2-8:2002 (IEC 61347-2-8:2000) | | | Electronic ballasts 电子镇流器 | PNS IEC 61347-2-3:2002 with Amd. 1:2006 (IEC 61347-2-3:2000) | | | Self-ballasted lamps / Compact fluorescent lamps | PNS IEC 968:2006 (IEC published 1988) | |
No. | | Philippine National Standard/s (PNS) | | | Self-ballasted LED lamps 自镇流LED灯 | PNS IEC 62560:2012 (IEC 62560:2011) | | | Christmas lights/ Lighting chains 圣诞灯饰/灯串 | | | | Double-capped fluorescent lamps 双帽荧光灯 | PNS IEC 61195:2006 (IEC 61195:1999) | |
No. | | Philippine National Standard/s (PNS) | | | Single-capped fluorescent lamps 单帽荧光灯 | PNS IEC 61199:2006 (IEC 61195:1999) | | | | PNS 38-1:1995 (IEC 432-1:1993 Amd. 01:1995) | | | Edison screw lamp holders 爱迪生螺纹灯座/圆螺纹灯座 | PNS 80:1997 (IEC 238:1996) | |
No. | | Philippine National Standard/s (PNS) | | | Lamp holders for tubular fluorescent lamps 管形荧光灯灯座 | PNS 42:1997 (IEC 400:1996) | | | | PNS 42:1997 (IEC 400:1996) | | | | PNS 45:1997 Amd. 01:1997 (IEC 155:1993 Amd. 01:1995) | |
No. | | Philippine National Standard/s (PNS) | | | | PNS 519:1991 PNS 1573-2:1997 (IEC 947-2:1995) | | | | | | | | PNS 56:1996 (ANSI/UL 512:1992) | | | PVC electrical tapes PVC电工胶带 | | |
No. | | Philippine National Standard/s (PNS) | | | | PNS 1486-1:1996 (IEC 884-1:1994) PNS 1572:1997 (IEC 83:1975) | | | | PNS 1486-1:1996 (IEC 884-1:1994) PNS 1572:1997 (IEC 83:1975) | | | | PNS 1486-1:1996 (IEC 884-1:1994) PNS 1572:1997 (IEC 83:1975) | |
No. | | Philippine National Standard/s (PNS) | | | | PNS 1485-1:1996 Amd. 01 & 02:1996 (IEC 669-1:1993 Amd. 01:1994 & Amd. 02:1995) | | | | | | | | | | | | |
No. | | Philippine National Standard/s (PNS) | | | PVC insulated flexible cords PVC绝缘软电线 | | | | Thermoplastic electric wires and cables 热塑电线电缆 | | |
