[DCDC] 礼品台灯专用升压恒流芯片
 楼主| aqbjxk2 发表于 2021-5-19 11:26 | 显示全部楼层 |阅读模式
简约台灯专用升压恒流驱动芯片
可调光台灯专用升压恒流芯片
礼品台灯专用升压恒流芯片
LED智能台灯专用升压恒流芯片
输入2.8V-30V升压恒流驱动芯片内置MOS大2A输出
AP9235
General Description
AP9235 is DC/DC step-up converter that deliver an
accurate constant current for driving LEDs. Operation
at a fixed switching frequency of 1MHz allows the
device to be used with small value external ceramic
capacitors and inductor. LEDs connected in series are
driven with a regulated current set by the external
resistor. The AP9235 is ideal for driving up to eight
white LEDs in series or up to 30V.
Ordering Information
Package Code
Temperature Code
Optional Spec Code
AP9235 □□□□(□□□□□□□□)□□□□
Temperature Range: -40°C to 85°C
Features
• Input voltage range: 2.8 to 30V
• Switch current limit 2A
• Drives LED strings up to 30V
• 1MHz fixed frequency minimizes the external
components
• Dimming frequency for EN/PWM pin:
20kHz~1MHz
• Internal softstart limits the inrush current
• Open LED over voltage protection
• RoHS Compliant and Halogen Free
Applications
• GPS Navigation Systems
• Handheld Devices
• Portable Media Players
Typical Applications
8、样板申请联系:
深圳市
如需要了解可以联系欧阳: 18811874036 13714437124(微信)QQ:2355558464
深圳市宝安西乡街道宝源路名优采购中心B座1区326
hk6108 发表于 2021-5-20 19:12 来自手机 | 显示全部楼层
30V ,2A ,荧光灯也能带了吧?!
