void BSP_LWIP_Init(void)
/* Initilialize the LwIP stack with RTOS */
tcpip_init( NULL, NULL );
/* IP addresses initialization with DHCP (IPv4) */
ipaddr.addr = 0;
netmask.addr = 0;
gw.addr = 0;
/* add the network interface (IPv4/IPv6) with RTOS */
netif_add(&gnetif, &ipaddr, &netmask, &gw, NULL, ðernetif_init, &tcpip_input);
/* Registers the default network interface */
netif_set_default(&gnetif);
if (netif_is_link_up(&gnetif))
/* When the netif is fully configured this function must be called */
netif_set_up(&gnetif);
else
/* When the netif link is down this function must be called */
netif_set_down(&gnetif);
/* Start DHCP negotiation for a network interface (IPv4) */
dhcp_start(&gnetif);
