排除某些文件:
- #工程名称
- TARGET = OSAL_example
- #设置编译器
- CC = arm-none-eabi-gcc
- #CC = /opt/arm-none-gcc-5.4/bin/arm-none-eabi-gcc
- OBJCOPY = arm-none-eabi-objcopy
- #OBJCOPY = /opt/arm-none-gcc-5.4/bin/arm-none-eabi-objcopy
- ARMSIZE = arm-none-eabi-size
- #获取当前工作目录
- TOP=.
- #设置源文件后缀,c或cpp
- EXT = c
- #设置自定义源文件目录
- # APP_DIR = $(TOP)/APP
- HARD_DIR = $(TOP)/HARDWARE
- PORT_STM32F4_DIR = $(TOP)/LWIP/port
- SYS_DIR = $(TOP)/SYSTEM
- FREERTOS_DIR = $(TOP)/FreeRTOS
- #设置源文件搜索路径
- VPATH += $(TOP)/Cpu/Core
- VPATH += $(TOP)/firmware
- VPATH += $(TOP)/FreeRTOS
- VPATH += $(FREERTOS_DIR)/portable/GCC/ARM_CM4_MPU
- VPATH += $(TOP)/FWLIB/src
- VPATH += $(TOP)/IAP:$(TOP)/LWIP:$(TOP)/HARDWARE
- VPATH += $(HARD_DIR)/ADC:$(HARD_DIR)/CAN:$(HARD_DIR)/DIN:$(HARD_DIR)/DMA:$(HARD_DIR)/DOUT:$(HARD_DIR)/DS1302:$(HARD_DIR)/FLASH:$(HARD_DIR)/GPRS:$(HARD_DIR)/KEY:$(HARD_DIR)/TIMER:$(HARD_DIR)/USART2:$(HARD_DIR)/WDG
- VPATH += $(TOP)/LWIP/app:$(TOP)/LWIP/cfg:$(TOP)/LWIP/drv
- VPATH += $(PORT_STM32F4_DIR)/FreeRTOS:$(PORT_STM32F4_DIR)/Standalone
- VPATH += $(SYS_DIR)/delay:$(SYS_DIR)/sys:$(SYS_DIR)/usart
- VPATH += $(TOP)/Task
- VPATH += $(TOP)/USER
- VPATH += $(TOP)/Main
- #设置中间目标文件目录
- OBJ_DIR = $(TOP)/OBJ
- #设定头文件包含目录
- INC_FLAGS += -I $(TOP)/FreeRTOS/include
- INC_FLAGS += -I $(TOP)/Cpu/Core
- INC_FLAGS += -I $(TOP)/firmware
- INC_FLAGS += -I $(FREERTOS_DIR)/include
- INC_FLAGS += -I $(FREERTOS_DIR)/portable/GCC/ARM_CM4_MPU
- INC_FLAGS += -I $(TOP)/FWLIB/inc
- INC_FLAGS += -I $(HARD_DIR)
- INC_FLAGS += -I $(HARD_DIR)/ADC
- INC_FLAGS += -I $(HARD_DIR)/CAN
- INC_FLAGS += -I $(HARD_DIR)/DIN
- INC_FLAGS += -I $(HARD_DIR)/DMA
- INC_FLAGS += -I $(HARD_DIR)/DOUT
- INC_FLAGS += -I $(HARD_DIR)/DS1302
- INC_FLAGS += -I $(HARD_DIR)/FLASH
- INC_FLAGS += -I $(HARD_DIR)/GPRS
- INC_FLAGS += -I $(HARD_DIR)/KEY
- INC_FLAGS += -I $(HARD_DIR)/TIMER
- INC_FLAGS += -I $(HARD_DIR)/USART2
- INC_FLAGS += -I $(HARD_DIR)/WDG
- INC_FLAGS += -I $(TOP)/IAP
- INC_FLAGS += -I $(TOP)/LWIP/app
- INC_FLAGS += -I $(TOP)/LWIP/cfg$(TOP)/LWIP/drv
- INC_FLAGS += -I $(PORT_STM32F4_DIR)/FreeRTOS
- INC_FLAGS += -I $(PORT_STM32F4_DIR)/Standalone
- INC_FLAGS += -I $(PORT_STM32F4_DIR)/arch
- INC_FLAGS += -I $(TOP)/Main
- INC_FLAGS += -I $(SYS_DIR)/delay
- INC_FLAGS += -I $(SYS_DIR)/sys
- INC_FLAGS += -I $(SYS_DIR)/usart
- INC_FLAGS += -I $(TOP)/Task
- INC_FLAGS += -I $(TOP)/USER
- INC_FLAGS += -I $(TOP)/LWIP/drv
- #编译选项
- CFLAGS += -W -Wall -g -mcpu=cortex-m3 -mthumb -O2 -std=gnu11 -mfloat-abi=softfp
- CFLAGS += -D USE_STDPERIPH_DRIVER
- CFLAGS += -D STM32F40XX
- CFLAGS += -D __TARGET_FPU_VFP
- #链接选项
- LFLAGS += -mthumb -mcpu=cortex-m3 -Wl,--start-group -lc -lm -Wl,--end-group -specs=nano.specs
- LFLAGS += -specs=nosys.specs -static -Wl,-cref,-u,Reset_Handler -Wl,-Map=Project.map -Wl,--gc-sections
- LFLAGS += -Wl,--defsym=malloc_getpagesize_P=0x80
- #链接启动文件和链接脚本
- LFLAGS += $(TOP)/CORE/startup_stm32f10x_hd.s
- LFLAGS += -T $(TOP)/CORE/stm32_flash.ld
- #固定源文件添加
- C_SRC += $(shell find $(TOP)/Cpu/Core -name '*.$(EXT)')
- C_SRC += $(shell find $(TOP)/firmware -name '*.$(EXT)')
- C_SRC += $(shell find $(TOP)/FreeRTOS -maxdepth 1 -name '*.$(EXT)')
- C_SRC += $(shell find $(FREERTOS_DIR)/portable/GCC/ARM_CM4_MPU -name '*.$(EXT)')
- C_SRC += $(shell find $(TOP)/FWLIB/src -name '*.$(EXT)' ! -name 'stm32f4xx_fmc.$(EXT)')
- C_SRC += $(shell find $(FREERTOS_DIR)/portable/MemMang -name 'heap_4.$(EXT)')
- #中间目标文件
- #C_OBJ += $(C_SRC:%.$(EXT)=%.o)
- C_SRC_NODIR = $(notdir $(C_SRC))
- C_OBJ = $(patsubst %.$(EXT), $(OBJ_DIR)/%.o,$(C_SRC_NODIR))
- #依赖文件
- C_DEP = $(patsubst %.$(EXT), $(OBJ_DIR)/%.d,$(C_SRC_NODIR))
- .PHONY: all clean rebuild upload test ctags
- all:$(C_OBJ)
- [url=home.php?mod=space&uid=3148]@echo[/url] "linking object to $(TARGET).elf"
- @$(CC) $(C_OBJ) -o $(TARGET).elf $(LFLAGS)
- @$(ARMSIZE) $(TARGET).elf
- @echo "create $(TARGET).hex from $(TARGET).elf"
- @$(OBJCOPY) $(TARGET).elf $(TARGET).hex -Oihex
- @$(ARMSIZE) $(TARGET).hex
- #$(OBJCOPY) $(TARGET).elf $(TARGET).bin -Obinary
- #静态模式
- #$(C_OBJ):%.o:%.$(EXT)
- # $(CC) -c $(CFLAGS) -o $[url=home.php?mod=space&uid=72445]@[/url] $<
- $(OBJ_DIR)/%.o:%.$(EXT)
- @mkdir -p OBJ
- @echo "building $<"
- @$(CC) -c $(CFLAGS) $(INC_FLAGS) -o $@ $<
- -include $(C_DEP)
- $(OBJ_DIR)/%.d:%.$(EXT)
- @mkdir -p OBJ
- @echo "making $@"
- [url=home.php?mod=space&uid=126030]@set[/url] -e;rm -f $@;$(CC) -MM $(CFLAGS) $(INC_FLAGS) $< > $@.$$;sed 's,\($*\)\.o[ :]*,$(OBJ_DIR)/\1.o $(OBJ_DIR)/\1.d:,g' < $@.$$ > $@;rm -f $@.$$
- clean:
- -rm -f $(OBJ_DIR)/*
- -rm -f $(shell find ./ -name '*.map')
- -rm -f $(shell find ./ -name '*.elf')
- -rm -f $(shell find ./ -name '*.bin')
- -rm -f $(shell find ./ -name '*.hex')
- rebuild: clean all
- test:
- @echo "Test !"
- @echo "C_SRC:$(C_SRC) "
- ctags:
- @ctags -R *
- upload:
- #openocd -f /usr/local/share/openocd/scripts/interface/jlink.cfg -f /usr/local/share/openocd/scripts/target/stm32f1x.cfg -c init -c "reset halt" -c "flash write_image erase $(TOP)/$(TARGET).hex" -c reset -c shutdown
- openocd -f /usr/local/share/openocd/scripts/interface/stlink-v2.cfg -f /usr/local/share/openocd/scripts/target/stm32f1x.cfg -c init -c "reset halt" -c "flash write_image erase $(TOP)/$(TARGET).hex" -c reset -c shutdown
