- 请教各位坛友,有没有遇到类似问题,使用的是官网demo程序。
- int main(void)
- int i;
- /* System clocks configuration */
- RCC_Configuration();
- /* GPIO configuration ------------------------------------------------------*/
- GPIO_Configuration();
- /* DMA1 channel1 configuration ----------------------------------------------*/
- DMA_Reset(DMA1_Channel1);
- DMA_DefaultInitParaConfig(&DMA_InitStructure);
- DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)&ADC1->RDOR;
- DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)ADC_RegularConvertedValueTab;
- DMA_InitStructure.DMA_Direction = DMA_DIR_PERIPHERALSRC;
- DMA_InitStructure.DMA_BufferSize = 3;
- DMA_InitStructure.DMA_PeripheralInc = DMA_PERIPHERALINC_DISABLE;
- DMA_InitStructure.DMA_MemoryInc = DMA_MEMORYINC_ENABLE;
- DMA_InitStructure.DMA_PeripheralDataWidth = DMA_PERIPHERALDATAWIDTH_HALFWORD;
- DMA_InitStructure.DMA_MemoryDataWidth = DMA_MEMORYDATAWIDTH_HALFWORD;
- DMA_InitStructure.DMA_Mode = DMA_MODE_CIRCULAR;
- DMA_InitStructure.DMA_Priority = DMA_PRIORITY_HIGH;
- DMA_InitStructure.DMA_MTOM = DMA_MEMTOMEM_DISABLE;
- DMA_Init(DMA1_Channel1, &DMA_InitStructure);
- /* Enable DMA1 channel1 */
- DMA_ChannelEnable(DMA1_Channel1, ENABLE);
- /* ADC1 configuration ------------------------------------------------------*/
- ADC_StructInit(&ADC_InitStructure);
- ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;
- ADC_InitStructure.ADC_ScanMode = ENABLE;
- ADC_InitStructure.ADC_ContinuousMode = ENABLE;
- ADC_InitStructure.ADC_ExternalTrig = ADC_ExternalTrig_None;
- ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
- ADC_InitStructure.ADC_NumOfChannel = 3;
- ADC_Init(ADC1, &ADC_InitStructure);
- /* ADC1 regular channels configuration */
- ADC_RegularChannelConfig(ADC1, ADC_Channel_1, 1, ADC_SampleTime_28_5);
- ADC_RegularChannelConfig(ADC1, ADC_Channel_2, 2, ADC_SampleTime_28_5);
- ADC_RegularChannelConfig(ADC1, ADC_Channel_3, 3, ADC_SampleTime_28_5);
- ADC_ExternalTrigConvCtrl(ADC1, ENABLE);
- /* Enable ADC1 DMA */
- ADC_DMACtrl(ADC1, ENABLE);
- /* Enable ADC1 */
- ADC_Ctrl(ADC1, ENABLE);
- /* Enable ADC1 reset calibration register */
- ADC_RstCalibration(ADC1);
- /* Check the end of ADC1 reset calibration register */
- while(ADC_GetResetCalibrationStatus(ADC1));
- /* Start ADC1 calibration */
- ADC_StartCalibration(ADC1);
- /* Check the end of ADC1 calibration */
- while(ADC_GetCalibrationStatus(ADC1));
- /* Start ADC1 Software Conversion */
- ADC_SoftwareStartConvCtrl(ADC1, ENABLE);
- while (1)
