[蓝牙芯片] TMOS系统调用失败,不知道问题在哪
 楼主| 妖妖妖 发表于 2021-8-4 14:50 | 显示全部楼层 |阅读模式
用的是CH573F,PA4 PA5接了2个LED我设想的是上电两个LED灯亮,1s后都熄灭,接着其中一个LED闪烁。但没看的啥效果,灯都没点亮,编译通过。
程序参考:https://www.cnblogs.com/iot-fan/p/13460082.html
#include "CH57x_common.h"
#include"tmos_demo_task.h"
* GLOBAL TYPEDEFS
__attribute__((aligned(4))) u32 MEM_BUF[BLE_MEMHEAP_SIZE/4];
__attribute__((section(".highcode")))
void Main_Circulation()
  while(1){
    TMOS_SystemProcess( );
int main()
  SetSysClock( CLK_SOURCE_PLL_60MHz );
  GPIOA_ModeCfg(GPIO_Pin_4,GPIO_ModeOut_PP_5mA);
  GPIOA_ModeCfg(GPIO_Pin_5,GPIO_ModeOut_PP_5mA);
  GPIOA_SetBits(GPIO_Pin_4);
  GPIOA_SetBits(GPIO_Pin_5);
  demo_task_init();
  Main_Circulation();
#include "tmos_demo_task.h"
//存储 当前task id 的全局变量
tmosTaskID  demo_task_id = INVALID_TASK_ID;
//系统消息处理的函数
//task的event处理回调函数,需要在注册task时候,传进去
static uint16_t demo_task_process_event( uint8_t task_id, uint16_t events ) {
    if ( events & SYS_EVENT_MSG ) {
        uint8_t *pMsg;
        if ( (pMsg = tmos_msg_receive( demo_task_id )) != NULL ) {
            tmos_msg_deallocate( pMsg );
        // return unprocessed events
        return (events ^ SYS_EVENT_MSG);
    //event 处理
    if(events & DEMO_TASK_TMOS_EVT_TEST_1) {
              GPIOA_ResetBits(GPIO_Pin_4);
              GPIOA_ResetBits(GPIO_Pin_5);
        return (events ^ DEMO_TASK_TMOS_EVT_TEST_1);
    //event 处理
    if(events & DEMO_TASK_TMOS_EVT_TEST_2) {
        tmos_start_task(demo_task_id,DEMO_TASK_TMOS_EVT_TEST_3,1600);
        return (events ^ DEMO_TASK_TMOS_EVT_TEST_2);
    //event 处理
    if(events & DEMO_TASK_TMOS_EVT_TEST_3) {
        tmos_start_task(demo_task_id,DEMO_TASK_TMOS_EVT_TEST_3,800);
        GPIOA_InverseBits( GPIO_Pin_4 );
        return (events ^ DEMO_TASK_TMOS_EVT_TEST_3);
    // Discard unknown events
    return 0;
uint8 tmos_demo_task_send_msg( uint8_t task_id,uint8_t *data ,uint16_t length ) {
    uint8_t *p_data;
    if ( task_id != TASK_NO_TASK ) {
        // Send the address to the task
        p_data = tmos_msg_allocate(length);
        if ( p_data ) {
            tmos_memcpy(p_data,data,length);
            tmos_msg_send( task_id, p_data );
            return ( SUCCESS );
    return ( FAILURE );
//初始化task
//包括注册函数,可以注册后去开启event
void demo_task_init( void ) {
    //注册task id,同事把该task的event处理函数传进去
    demo_task_id  = TMOS_ProcessEventRegister( demo_task_process_event );
    //立即开始一个event
    tmos_set_event(demo_task_id,DEMO_TASK_TMOS_EVT_TEST_1);
    //开始一个定时event,1s后产生,当前语句只会产生一次event
    //可以在event产生后去开启event,可以是别的task的,也可以是当前task的event
    tmos_start_task(demo_task_id,DEMO_TASK_TMOS_EVT_TEST_2,1600);
CH573F-TMOS-Demo.zip (631.66 KB, 下载次数: 7)
weifeng90 发表于 2021-8-4 18:55 来自手机 | 显示全部楼层
TMOS系统?没看明白。
WCHTech2 发表于 2021-8-5 09:32 | 显示全部楼层
TMOS的时钟是基于RTC运行,单位为625us。如需测试TMOS,建议用BLE文件夹下的broadcast或peripheral例程测试,不要新建工程。
单片小菜 发表于 2021-8-5 11:17 | 显示全部楼层
看见版主的回复,我发现我的问题出现在什么地方了。我自己新建的工程。
 楼主| 妖妖妖 发表于 2021-8-6 00:48 | 显示全部楼层
TMOS的时钟是基于RTC运行,单位为625us。如需测试TMOS,建议用BLE文件夹下的broadcast或peripheral例程测试 ...
好的
 楼主| 妖妖妖 发表于 2021-8-6 00:50 | 显示全部楼层
TMOS系统?没看明白。
根据OSAL简化来的
