[verilog] ISE 13.4 遇到 Process "Place & Route" failed
 楼主| WeToget 发表于 2021-11-2 17:35 | 显示全部楼层 |阅读模式
Generating "PAR" statistics.
INFO:Par:459 - The Clock Report is not displayed in the non timing-driven mode.
Timing Score: 1183542 (Setup: 1183542, Hold: 0)
Asterisk (*) preceding a constraint indicates it was not met.
   This may be due to a setup or hold violation.
  Constraint                                |    Check    | Worst Case |  Best Case | Timing |   Timing
                                            |             |    Slack   | Achievable | Errors |    Score
  Autotimespec constraint for clock net clk | SETUP       |         N/A|    26.656ns|     N/A|     1183536
  _BUFGP                                    | HOLD        |     0.266ns|            |       0|           0
  Autotimespec constraint for clock net clk | SETUP       |         N/A|     2.913ns|     N/A|           6
  _count                                    | HOLD        |     0.508ns|            |       0|           0
  Autotimespec constraint for clock net sta | SETUP       |         N/A|     2.907ns|     N/A|           0
  te[4]_PWR_35_o_Mux_246_o                  | HOLD        |     0.664ns|            |       0|           0
2 constraints not met.
INFO:Timing:2761 - N/A entries in the Constraints List may indicate that the
   constraint is not analyzed due to the following: No paths covered by this
   constraint; Other constraints intersect with this constraint; or This
   constraint was disabled by a Path Tracing Control. Please run the Timespec
   Interaction Report (TSI) via command line (trce tsi) or Timing Analyzer GUI.
Generating Pad Report.
716 signals are not completely routed. See the Kem_Enc.unroutes file for a list of all unrouted signals.
WARNING:Par:100 - Design is not completely routed. There are 716 signals that are not
   completely routed in this design. See the "Kem_Enc.unroutes" file for a list of
   all unrouted signals. Check for other warnings in your PAR report that might
   indicate why these nets are unroutable. These nets can also be evaluated
   in FPGA Editor by selecting "Unrouted Nets" in the List Window.
Total REAL time to PAR completion: 2 hrs 25 mins 47 secs
Total CPU time to PAR completion: 2 hrs 25 mins 31 secs
Peak Memory Usage:  5232 MB
Placer: Placement generated during map.
Routing: Completed - errors found.
Number of error messages: 0
Number of warning messages: 5
Number of info messages: 2
Writing design to file Kem_Enc.ncd
PAR done!
 楼主| WeToget 发表于 2021-11-2 17:36 | 显示全部楼层
各位高手,求助,希望大家能够指导一下错误原因,感谢!
