- //*********IAP bootloader 程序中的 中断向量表 1 **************************
- extern void _stext(); /* startup routine */
- struct interrupt_vector const UserISR_IRQ[32] [url=home.php?mod=space&uid=72445]@[/url] MAIN_USER_RESET_ADDR;
- //redirected interrupt table
- struct interrupt_vector const _vectab[] = {
- {0x82, (interrupt_handler_t)_stext}, /* reset */ //note:向量表代码开始位置为
- 0x8000,0x82 后面的 24bits 存放 0x9000
- {0x82, (interrupt_handler_t)(UserISR_IRQ+ 1)}, /* trap */ //note:代码位于
- 0x8001,0x82 后面的 24bits 存放 0x9001
- {0x82, (interrupt_handler_t)(UserISR_IRQ+ 2)}, /* irq0 */
- {0x82, (interrupt_handler_t)(UserISR_IRQ+ 3)}, /* irq1 */
- {0x82, (interrupt_handler_t)(UserISR_IRQ+ 4)}, /* irq2 */
- {0x82, (interrupt_handler_t)(UserISR_IRQ+ 5)}, /* irq3 */
- Step1 发生中断
- Step2 跳转到向量表 2
- Step3 跳转到具体的处理函数
- Step4 APP 软件发生中断
- {0x82, (interrupt_handler_t)(UserISR_IRQ+ 6)}, /* irq4 */
- {0x82, (interrupt_handler_t)(UserISR_IRQ+ 7)}, /* irq5 */
- {0x82, (interrupt_handler_t)(UserISR_IRQ+ 8)}, /* irq6 */
- {0x82, (interrupt_handler_t)(UserISR_IRQ+ 9)}, /* irq7 */
- {0x82, (interrupt_handler_t)(UserISR_IRQ+10)}, /* irq8 */
- {0x82, (interrupt_handler_t)(UserISR_IRQ+11)}, /* irq9 */
- {0x82, (interrupt_handler_t)(UserISR_IRQ+12)}, /* irq10 */
- {0x82, (interrupt_handler_t)(UserISR_IRQ+13)}, /* irq11 */
- {0x82, (interrupt_handler_t)(UserISR_IRQ+14)}, /* irq12 */
- {0x82, (interrupt_handler_t)(UserISR_IRQ+15)}, /* irq13 */
- {0x82, (interrupt_handler_t)(UserISR_IRQ+16)}, /* irq14 */
- {0x82, (interrupt_handler_t)(UserISR_IRQ+17)}, /* irq15 */
- {0x82, (interrupt_handler_t)(UserISR_IRQ+18)}, /* irq16 */
- {0x82, (interrupt_handler_t)(UserISR_IRQ+19)}, /* irq17 */
- {0x82, (interrupt_handler_t)(UserISR_IRQ+20)}, /* irq18 */
- {0x82, (interrupt_handler_t)(UserISR_IRQ+21)}, /* irq19 */
- {0x82, (interrupt_handler_t)(UserISR_IRQ+22)}, /* irq20 */
- {0x82, (interrupt_handler_t)(UserISR_IRQ+23)}, /* irq21 */
- {0x82, (interrupt_handler_t)(UserISR_IRQ+24)}, /* irq22 */
- {0x82, (interrupt_handler_t)(UserISR_IRQ+25)}, /* irq23 */
- {0x82, (interrupt_handler_t)(UserISR_IRQ+26)}, /* irq24 */
- {0x82, (interrupt_handler_t)(UserISR_IRQ+27)}, /* irq25 */
- {0x82, (interrupt_handler_t)(UserISR_IRQ+28)}, /* irq26 */
- {0x82, (interrupt_handler_t)(UserISR_IRQ+29)}, /* irq27 */
- {0x82, (interrupt_handler_t)(UserISR_IRQ+30)}, /* irq28 */
- {0x82, (interrupt_handler_t)(UserISR_IRQ+31)}, /* irq29 */
