[全新] ZCC6601替代SN6501和SN6505
 楼主| SWdianzi 发表于 2021-12-23 15:51 | 显示全部楼层 |阅读模式
FEATURES
• Push-Pull Driver for Small Transformers
• Wide range 3 V - 12 V Supply
• High Primary-side Current Drive:  – 5 V Supply: 600 mA (max)  – 3.3 V Supply: 300 mA (max)
• Low Ripple on Rectified Output Permits Small Output Capacitors
• Soft start and Current limit
• Thermal shutdown
• Small 5-pin SOT23 Package
APPLICATIONS
• Isolated Interface Power Supply for CAN, RS- 485, RS-422, RS-232, SPI, I2C, Low-Power LAN
• Industrial Automation
• Process Control
• Medical Equipment
DESCRIPTION
The ZCC6601 is a monolithic oscillator/power-driver, specifically designed for small form factor, isolated power supplies in isolated interface applications. It drives a low-profile, center-tapped transformer primary from a 3V to12 V DC power supply. The secondary can be wound to provide any isolated voltage based on transformer turns ratio. The ZCC6601 consists of an oscillator followed by a gate drive circuit that provides the complementary output signals to drive the ground referenced N-channel power switches. The internal logic ensures break-before-make action between the two switches. The ZCC6601 is available in a small SOT23-5 package, and is specified for operation at temperatures from –40°C to 125°C.
