流程
(简单的发送数据)
GPIO时钟使能
串口时钟使能
串口的GPIO配置
写初始化串口函数,配置串口USART_Init(USART1,&USART_InitStruct);
开启(使能)串口USART_Cmd(USART1, ENABLE);
附上代码
- void NVIC_Config_USART()
- NVIC_InitTypeDef NVIC_InitStruct;
- NVIC_InitStruct.NVIC_IRQChannel = USART1_IRQn;
- NVIC_InitStruct.NVIC_IRQChannelPreemptionPriority = 1;
- NVIC_InitStruct.NVIC_IRQChannelSubPriority = 1;
- NVIC_InitStruct.NVIC_IRQChannelCmd = ENABLE;
- NVIC_Init(& NVIC_InitStruct);
- NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
- void Init_UART()
- GPIO_InitTypeDef GPIOInitstruct;
- USART_InitTypeDef USART_InitStruct;
- RCC_APB2PeriphClockCmd( RCC_APB2Periph_GPIOA,ENABLE); //开启串口对应的GPIO时钟
- RCC_APB2PeriphClockCmd( RCC_APB2Periph_USART1,ENABLE);//开启串口1的时钟 :Tx-A9 RX-A10,开
- GPIOInitstruct.GPIO_Mode = GPIO_Mode_AF_PP; //设置串口GPIO模式(有两个)
- GPIOInitstruct.GPIO_Pin = GPIO_Pin_9;
- GPIOInitstruct.GPIO_Speed = GPIO_Speed_50MHz; //Tx GPIO配置
- GPIO_Init(GPIOA,&GPIOInitstruct); //设置TX为推免输出模式
- GPIOInitstruct.GPIO_Mode = GPIO_Mode_IN_FLOATING;
- GPIOInitstruct.GPIO_Pin = GPIO_Pin_10;
- GPIO_Init(GPIOA,&GPIOInitstruct); //设置RX GPIO配置
- USART_InitStruct.USART_BaudRate = 115200;
- USART_InitStruct.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
- USART_InitStruct.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
- USART_InitStruct.USART_Parity = USART_Parity_No;
- USART_InitStruct.USART_StopBits = USART_StopBits_1;
- USART_InitStruct.USART_WordLength = USART_WordLength_8b;
- USART_Init(USART1,&USART_InitStruct); //配置好串口
- NVIC_Config_USART(); //配置NVIC
- USART_ITConfig(USART1,USART_IT_RXNE,ENABLE); // 使能接收中断
- USART_Cmd(USART1, ENABLE); //开启串口
- //串口接受,会引发中断
- void UART_SendByte(USART_TypeDef * USARTx, uint8_t dat)
- USART_SendData(USART1, dat);
- while((USART_GetFlagStatus(USART1,USART_FLAG_TC))== RESET);
- //发送缓冲区为空,状态置1, 写入一个数据,状态置0,灯数据发送借书,这个状态寄存器就变成1
- //实现了串口发送一个字节
- void UART_SendString(USART_TypeDef * USARTx, char* string)
- char * str = string;//指向string
- while(*str) //只要str不为0,表示字符串还没有结束
- UART_SendByte(USARTx, *str);
- str++;
- void LED_Init(void)
- GPIO_InitTypeDef GPIO_InitStructure;
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB|
- RCC_APB2Periph_GPIOE, ENABLE); //使能 PB,PE 端口时钟
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5; //LED0-->PB.5 推挽输出
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //推挽输出
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
- GPIO_Init(GPIOB, &GPIO_InitStructure);
- GPIO_SetBits(GPIOB,GPIO_Pin_5); //PB.5 输出高
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5; //LED1-->PE.5 推挽输出
- GPIO_Init(GPIOE, &GPIO_InitStructure);
- GPIO_SetBits(GPIOE,GPIO_Pin_5); //PE.5 输出高
