[DemoCode下载] [NDA102] Control AS7221 by DALI Command
 楼主| 奔跑的牛 发表于 2022-1-25 15:23 | 显示全部楼层 |阅读模式
  • Application: This example code is to add UART interface to the original DALI application project for communication with AS7221, so that DALI
    Command can control the AS7221 module.
  • BSP Version: 102_207_209_NDA102_200707_Lib
  • Hardware: DALI_SLAVE_NDA102EC1 V1.0
This example code can receive the instructions sent by the DALI (Digital Addressable Lighting Interface) host, and then send commands to AS7221 through the UART1 interface to control the lamp behavior in the module, such as adjusting brightness, color temperature, gradient time and so on.
You can download the sample code at https://www.nuvoton.com/resource-downlo ... 0803135654
海滨消消 发表于 2022-1-26 11:08 来自手机 | 显示全部楼层
啥意思啊这发的
认证:新唐科技
简介:新唐科技晶圆代工(源自于华邦电子六英寸晶圆厂)座落于台湾新竹科学园区内,月产能为45,000片,自1992年起,拥有超过20年晶圆代工服务经验,于2008年自华邦电子分割后,完全专注于晶圆代工。新唐晶圆代工厂目前提供0.35微米以上工艺,包括一般逻辑(Generic Logic)、混合信号(Mixed Signal)、高压(High Voltage)、超高压(Ultra High Voltage)、电源管理(Power Management)、Mask ROM (Flat Cell)、嵌入式记忆体(embedded Logic Non-Volatile Memory)与客制化工艺(如:IGBT, MOSFET, TVS, BioChip, Pressure Sensor, and Light Sensor)等。
257
