- DMA初始化
- void MYDMA_Config(void)
- __HAL_RCC_DMA2_CLK_ENABLE();//DMA2时钟使能
- //Tx DMA配置
- ADC1_DMA_Handler.Instance=DMA2_Stream0; //数据流选择
- ADC1_DMA_Handler.Init.Channel=DMA_CHANNEL_0; //通道选择
- ADC1_DMA_Handler.Init.Direction=DMA_PERIPH_TO_MEMORY; //存储器到外设
- ADC1_DMA_Handler.Init.PeriphInc=DMA_PINC_DISABLE; //外设增量模式
- ADC1_DMA_Handler.Init.MemInc=DMA_MINC_ENABLE; //存储器增量模式
- ADC1_DMA_Handler.Init.PeriphDataAlignment=DMA_PDATAALIGN_HALFWORD; //外设数据长度:16位
- ADC1_DMA_Handler.Init.MemDataAlignment=DMA_PDATAALIGN_HALFWORD; //存储器数据长度:16位
- ADC1_DMA_Handler.Init.Mode=DMA_CIRCULAR; //外设普通模式
- ADC1_DMA_Handler.Init.Priority=DMA_PRIORITY_MEDIUM; //中等优先级
- ADC1_DMA_Handler.Init.FIFOMode=DMA_FIFOMODE_DISABLE;
- ADC1_DMA_Handler.Init.FIFOThreshold=DMA_FIFO_THRESHOLD_FULL;
- ADC1_DMA_Handler.Init.MemBurst=DMA_MBURST_SINGLE; //存储器突发单次传输
- ADC1_DMA_Handler.Init.PeriphBurst=DMA_PBURST_SINGLE; //外设突发单次传输
- __HAL_LINKDMA(&ADC1_Handler,DMA_Handle,ADC1_DMA_Handler); //将DMA与USART1联系起来(发送DMA)
- ADC1_DMA_Handler.Instance->PAR = (u32)&ADC1->DR;//外设地址
- ADC1_DMA_Handler.Instance->M0AR = (vu32)ADC_ConvertedValue;
- ADC1_DMA_Handler.Instance->NDTR = 8;
- HAL_DMA_DeInit(&ADC1_DMA_Handler);
- HAL_DMA_Init(&ADC1_DMA_Handler);
- HAL_DMA_Start(&ADC1_DMA_Handler, (u32)&ADC1->DR, (vu32)ADC_ConvertedValue, N*ADC_CHANNELS);
- *名称: MY_ADC_Init()
- *描述: 配置AD转换,使用ADC1,DMA2,转换8个通道
- *入口参数: 无
- *出口参数: 无
- void MY_ADC_Init(void)
- ADC_ChannelConfTypeDef ADC1_ChanConf;
- ADC1_Handler.Instance=ADC1;
- ADC1_Handler.Init.ClockPrescaler=ADC_CLOCK_SYNC_PCLK_DIV4; //4分频,ADCCLK=PCLK2/4=90/4=22.5MHZ
- ADC1_Handler.Init.Resolution=ADC_RESOLUTION_12B; //12位模式
- ADC1_Handler.Init.DataAlign=ADC_DATAALIGN_RIGHT; //右对齐
- ADC1_Handler.Init.ScanConvMode=ENABLE; //扫描模式?
- ADC1_Handler.Init.EOCSelection=DISABLE; //关闭EOC中断
- ADC1_Handler.Init.ContinuousConvMode=ENABLE; //开启连续转换
- ADC1_Handler.Init.NbrOfConversion=8; //8个转换在规则序列中 也就是只转换规则序列1
- ADC1_Handler.Init.DiscontinuousConvMode=DISABLE; //禁止不连续采样模式
- ADC1_Handler.Init.NbrOfDiscConversion=0; //不连续采样通道数为0
- ADC1_Handler.Init.ExternalTrigConv=ADC_SOFTWARE_START; //软件触发
- ADC1_Handler.Init.ExternalTrigConvEdge=ADC_EXTERNALTRIGCONVEDGE_NONE;//使用软件触发
- ADC1_Handler.Init.DMAContinuousRequests=ENABLE; //开启DMA请求
- HAL_ADC_Init(&ADC1_Handler); //初始化
- //转换序列
- ADC1_ChanConf.Channel = ADC_CHANNEL_8;
- ADC1_ChanConf.Rank = 1; //第1个序列,序列1
- ADC1_ChanConf.SamplingTime = ADC_SAMPLETIME_480CYCLES;
- ADC1_ChanConf.Offset = 0;
- HAL_ADC_ConfigChannel(&ADC1_Handler, &ADC1_ChanConf);
- ADC1_ChanConf.Channel = ADC_CHANNEL_15;
- ADC1_ChanConf.Rank = 2; //第1个序列,序列2
- ADC1_ChanConf.Channel = ADC_CHANNEL_14;
- ADC1_ChanConf.Rank = 3; //第1个序列,序列3
- ADC1_ChanConf.Channel = ADC_CHANNEL_7;
- ADC1_ChanConf.Rank = 4; //第1个序列,序列4
- ADC1_ChanConf.Channel = ADC_CHANNEL_6;
- ADC1_ChanConf.Rank = 5; //第1个序列,序列5
- ADC1_ChanConf.Channel = ADC_CHANNEL_3;
- ADC1_ChanConf.Rank = 6; //第1个序列,序列6
- ADC1_ChanConf.Channel = ADC_CHANNEL_9;
- ADC1_ChanConf.Rank = 7; //第1个序列,序列6
- ADC1_ChanConf.Channel = ADC_CHANNEL_5;
- ADC1_ChanConf.Rank = 8; //第1个序列,序列6
- // HAL_ADC_Start(&ADC1_Handler);
- MYDMA_Config();//初始化并开启DMA
- HAL_ADC_Start_DMA(&ADC1_Handler, (vu32*)&ADC_ConvertedValue, N*ADC_CHANNELS);
- //ADC,引脚配置,时钟使能
- //此函数会被HAL_ADC_Init()调用
- //hadc:ADC句柄
- void HAL_ADC_MspInit(ADC_HandleTypeDef* hadc)
- GPIO_InitTypeDef GPIO_Initure;
- __HAL_RCC_ADC1_CLK_ENABLE(); //使能ADC1时钟
- __HAL_RCC_GPIOA_CLK_ENABLE(); //开启GPIOA时钟
- __HAL_RCC_GPIOB_CLK_ENABLE(); //开启GPIOA时钟
- __HAL_RCC_GPIOC_CLK_ENABLE(); //开启GPIOA时钟
- GPIO_Initure.Pin=GPIO_PIN_3|GPIO_PIN_6|GPIO_PIN_7|GPIO_PIN_5; //PA3,6,7, 5用于测试
- GPIO_Initure.Mode=GPIO_MODE_ANALOG; //模拟
- GPIO_Initure.Pull=GPIO_NOPULL; //不带上下拉
- HAL_GPIO_Init(GPIOA,&GPIO_Initure);
- GPIO_Initure.Pin=GPIO_PIN_0|GPIO_PIN_1; //PB0,1
- HAL_GPIO_Init(GPIOB,&GPIO_Initure);
- GPIO_Initure.Pin=GPIO_PIN_4|GPIO_PIN_5; //PC4,5
- *名称:getAdc()
- *描述:读取指定通道AD值
- *入口参数:通道号channel,取值分为0到(ADC_CHANNELS-1)
- *出口参数:AD值
- uint16 getADC_CH(uint8 channel){
- u16 tbuf[N];
- __IO u32 tdat=0;
- u8 ti;
- //判断传入参数是否合法
- if(channel>=ADC_CHANNELS){
- return 0;
- for(ti=0;ti<N;ti++)
- tbuf[ti]=ADC_ConvertedValue[ti][channel];
- bubbleSort(tbuf, N);
- for(ti=25;ti<(N-25);ti++)
- tdat+=tbuf[ti];
- tdat/=50;
- if(tdat<5)
- tdat=0;
- return tdat;
