keil5 下载程序出错
 楼主| XUWENTAO 发表于 2022-2-9 18:12 | 显示全部楼层 |阅读模式
主控 GD32F407IGH6  使用keil5下载固件出现错误,错误如下搜索
复制
Contents mismatch at: 08001056H  (Flash=00H  Required=08H) !
Contents mismatch at: 08001057H  (Flash=00H  Required=60H) !
Contents mismatch at: 08001059H  (Flash=00H  Required=BFH) !
Contents mismatch at: 0800105BH  (Flash=00H  Required=98H) !
Contents mismatch at: 0800105CH  (Flash=00H  Required=40H) !
Contents mismatch at: 0800105DH  (Flash=00H  Required=1CH) !
Contents mismatch at: 0800105FH  (Flash=00H  Required=90H) !
Contents mismatch at: 08001060H  (Flash=00H  Required=B8H) !
Contents mismatch at: 08001061H  (Flash=00H  Required=42H) !
Contents mismatch at: 08001063H  (Flash=00H  Required=D9H) !
Contents mismatch at: 08001064H  (Flash=00H  Required=05H) !
Contents mismatch at: 08001065H  (Flash=00H  Required=E0H) !
Contents mismatch at: 08001066H  (Flash=00H  Required=20H) !
Contents mismatch at: 08001067H  (Flash=00H  Required=68H) !
Contents mismatch at: 08001069H  (Flash=00H  Required=68H) !
Contents mismatch at: 0800106BH  (Flash=00H  Required=F0H) !
Contents mismatch at: 0800106CH  (Flash=00H  Required=01H) !
Contents mismatch at: 0800106FH  (Flash=00H  Required=28H) !
Contents mismatch at: 08001070H  (Flash=00H  Required=F3H) !
Contents mismatch at: 08001071H  (Flash=00H  Required=D1H) !
Too many errors to display !
Error: Flash Download failed  -  "Cortex-M4"
Flash Load finished at 17:58:26
呐咯密密 发表于 2022-2-10 14:06 | 显示全部楼层
keil5 下载程序出错
更新一下固件,全篇擦除一下,检查复位电路,都试试搜索
复制
