DR5018
IPQ5018, support 2x WiFi 6E Card, support BT5.1
802.11ax IPQ5018 2X2 2.4G
Dual-core ARM 64bit A53@1.0GHz Processor
512MB DDRL3L System Memory
4MB NOR Flash, 128MB NAND Flash
2x2 On-board 2.4GHz radio,up to 573Mbps physical Data Rate
Support BT5.1
Two PCIe2.0 connector can support QCN90xx production
Parameter
| Rating | Unit | Supply Voltage
| 12 | V | Operating Temperature Range
| -40 to +70 | ºC | Storage Temperature Range
| -45 to +105 | ºC | Operating Humidity Range
| 5 to +95 (non-condensing) | % |
Symbol
| Parameter | CPU
| Qualcomm-Atheros IPQ5018
| CPU Frequency
| Dual-core ARM 64 bit A53 @1.0 GHz processor
| System Memory
| 512MB DDR3L 16-bit interface with 32-bit memory bus design
| Ethernet Port
| 4 x 1Gbps Ethernet Ports or 1X2.5Gbps Ethernet Port;
1 x1Gbps Ethernet Port
| NGFF Slot
| 2 X M.2 (NGFF) “E Key” Socket with MiniPCIe 2.0(For WiFi Module)
| EMMC
| 4G/8G(optional)
| USB /header
| 1x USB 3.0 Port
| POE
| NA
| DC Jack
| 12V power supply
| LED header
| LED for power ,Wifi strength
| Serial Port
| support
| Wireless
| On-board 2x22.4GHz MU-MIMO OFDMA 802.11b/802.11g/802.11n/802.11ax,max 23dBm per chain
2x IPEX Connectors
| Bluetooth | BT5.1
| Nor Flash
| 8MB
| Nand Flash
| 128 MB
| DDR
| 512MB
| Dimension
| 185mm x 116mm
BY Wallys Communications (Suzhou) Co LTD
EMAIL:sales@wallystech.com
WEB:https://www.wallystech.com/
wifi6 router
wifi 6E
Wi-Fi 6E
Wi-Fi 6
WiFi 6
802.11ax
802.11ac
wireless
QCN9074/QCN9024/QCN9072/QCA9882/QCA9880/QCN6024
IPQ6010/IPQ6018/IPQ6000/IPQ8072/IPQ5018/IPQ8074
IPQ4029/IPQ4019
Dipole Antenna
panel antenna
Smart antenna
omni antenna
Wireless Access Point
