[PCB] IPQ8074A/IPQ8072A/QCA9880/QCN9074 4x4 2.4G 8x8 5G 802.11ax
 楼主| wirelesswifi6 发表于 2022-5-30 10:19 | 显示全部楼层 |阅读模式
IPQ8074A/IPQ8072A/QCA9880/QCN9074 4x4 2.4G 8x8 5G 802.11axFeatures
■ Qualcomm Atheros IPQ8074A AR Quad Core CPU
■ On-board 5GHz radio, up to 4804Mbps physical data rate 32MB NOR Flash, 256MB NAND Flash
■ On-board 2.4GHz radio, up to 1147Mbps physical data rate
■ Support 11ax TX Beamforming
■ Support 11ac/ax MU-MIMO DL and UL
■ Support OFDMA DL and UL
■ Tri-band support with 5G SBS (4x4/5GHz + 4x4/5GHz) + 4x4/2.4GHz
■ Supports Dynamic Frequency Selection (DFS)
    Absolute Maximum Rating
    Parameter
    Rating
    Unit
    Operating Temperature Range
    -20 to +70
    ºC
    Storage Temperature Range
    -40 to +90
    ºC
    Operating Humidity Range
    5 to +95 (non-condensing)
    Storage Humidity Range
    0 to +90 (non-condensing)
    Hardware Specifications
    Symbol
    Parameter
    CPU
    Qualcomm Atheros Quad Core ARM Cortex 64-bit A53 Processor IPQ8074A 2.2GHz CPU
    CPU Frequency
    Derived from Qualcomm Atheros AP.HK01
    System Memory
    1GB (2x 512MB) DDR3L 32-bit interface
    Frequency Range
    2.412GHz to 2.472GHz, 5.150GHz to 5.825GHz
    Modulation Techniques
    OFDMA: BPSK, QPSK, 16-QAM, 64-QAM, 256-QAM, 1024-QAM
    NGFF Slot for 5G Module
    M.2 (NGFF) “B Key” Socket with PCIe 3.0 interface
    Optional Onboard Modules
    Supports 1x BT module,1x ZigBee module,1x Touch pad connector,1x Audio header,1x LCD display header
    Flash
    NOR Flash: 32MB NAND Flash: 256MB
    eMMC: 8GB
    Wireless
    On-board 4x4 2.4GHz MU-MIMO 802.11b/g/n/ax, max TBDdBm per chain
    On-board 2x(4x4) or 8x8 5GHz MU-MIMO 802.11a/802.11n/802.11ac/802.11ax, max TBDdBm per chain
    12x U.FL connectors
    Reset Buttons
    2x Hardware reset button, 1x WPS reset button
    DC Jack Input
    1x DC Jack Connector: 12V, 5A
    Interface
    5x Gigabit Ethernet (1GbE) LAN/WAN RJ45 Port (Auto MDI-X)
    1x 10Gigabit Ethernet (10GbE) LAN/WAN RJ45 Port (Auto MDI-X) 1x SFP+ Port
    2x USB 3.0 Port
    1x Serial Port 12 Pin Connector 1x JTAG 20 Pin Connector
    1x micro SD Card Socket
    1x M.2 Slot
    LED
    13x LED indicators, 2 additional LED on Ethernet port
    Power Consumption
    TBD
    Wallys Communications (Suzhou) Co LTD  develops, designs and manufactures wireless communication products, including routers, network cards, AP and antennas. Customization is also supported, The market is global, We're a supplier to Facebook. welcome to consult. (Web:wallystech  com)
    <span]WEB:
    https://www.wallystech.com/
