- static int snd_pcm_init(snd_para_t *snd_para,snd_pcm_t *pcm)
- snd_pcm_hw_params_t *hwparams = NULL;
- int ret;
- if(snd_para->alsa_pcm_dev_name!=NULL)
- // ret = snd_pcm_open(&(pcm), snd_para->alsa_pcm_dev_name, snd_para->stream, 0);
- ret = snd_pcm_open(&(pcm), ALSA_PCM_PLAYBACK_DEV, snd_para->stream, 0);
- else{
- puts(" pcm dev name is null\n");
- return -1;
- if (0 != ret) {
- fprintf(stderr, "snd_pcm_open error: %s: %s\n",
- snd_para->alsa_pcm_dev_name, snd_strerror(ret));
- return -1;
- snd_pcm_hw_params_malloc(&hwparams);
- ret = snd_pcm_hw_params_any(pcm, hwparams);
- if (0 != ret) {
- fprintf(stderr, "snd_pcm_hw_params_any error: %s\n", snd_strerror(ret));
- goto err2;
- ret = snd_pcm_hw_params_set_access(pcm, hwparams, snd_para->_access);
- if (0 != ret) {
- fprintf(stderr, "snd_pcm_hw_params_set_access error: %s\n", snd_strerror(ret));
- goto err2;
- ret = snd_pcm_hw_params_set_format(pcm, hwparams, snd_para->fmt);
- if (0 != ret) {
- fprintf(stderr, "snd_pcm_hw_params_set_format error: %s\n", snd_strerror(ret));
- goto err2;
- ret = snd_pcm_hw_params_set_rate(pcm, hwparams, snd_para->sample_rate, 0);
- if (0 != ret) {
- fprintf(stderr, "snd_pcm_hw_params_set_rate error: %s\n", snd_strerror(ret));
- goto err2;
- ret = snd_pcm_hw_params_set_channels(pcm, hwparams, snd_para->channels);
- if (0!= ret) {
- fprintf(stderr, "snd_pcm_hw_params_set_channels error: %s\n", snd_strerror(ret));
- goto err2;
- ret = snd_pcm_hw_params_set_period_size(pcm, hwparams, snd_para->period_size, 0);
- if (0 != ret) {
- fprintf(stderr, "snd_pcm_hw_params_set_period_size error: %s\n", snd_strerror(ret));
- goto err2;
- ret = snd_pcm_hw_params_set_periods(pcm, hwparams, snd_para->periods, 0);
- if (0!= ret) {
- fprintf(stderr, "snd_pcm_hw_params_set_periods error: %s\n", snd_strerror(ret));
- goto err2;
- ret = snd_pcm_hw_params(pcm, hwparams);
- snd_pcm_hw_params_free(hwparams);
- if (0 != ret) {
- fprintf(stderr, "snd_pcm_hw_params error: %s\n", snd_strerror(ret));
- goto err1;
- return 0;
- err2:
- snd_pcm_hw_params_free(hwparams); //释放内存
- err1:
- snd_pcm_close(pcm); //关闭 pcm 设备
- return -1;
