CCS调试时遇到的小问题 憋了好多天了 跪谢各位
 楼主| wansuiye 发表于 2012-4-12 11:08 | 显示全部楼层 |阅读模式
CCS上调试一个语音算法的代码(.c,.h),用的6446 simulator模式,编译链接完毕以后,将声场的.out文件load以后在运行,就会提示:
Error:Illegal opcode (XXXX) at pc= 0x0000000c  Illgal opcode at pc =0x0000000c
  Error:SIMmay not be in stable,Advisable to correct the error before running这样类似的警告
下面是我尝试只测试打开语音的代码,也出现了相同的问题,不知道什么原因,可能是程序或是设置或是cmd文件,跪谢各位了,全部分奉上
int main( )
short int * speech_samples; /* Array of speechsamples */
INT32 file_length;/* Number of samples in speech file */
INT32 num_read; /*number of elements read from file */
charpSpeechFilename[100];
  char *argv[]={"dg105.wav"};
FILE *speech_file;
  intPartitionNumber;
FLOAT PredictedMos;
strcpy(pSpeechFilename,argv[0]);
/* open speech file*/
if((speech_file =fopen(pSpeechFilename, "rb")) == NULL )
printf("Cannot open file %s\n", pSpeechFilename ) ;
exit(-1) ;
/* Read speechsamples from file */
fseek(speech_file,0 , SEEK_END) ;
file_length =(ftell(speech_file))/(sizeof(short int)) ;
fseek(speech_file,0 , SEEK_SET) ;
speech_samples =(short int *)calloc(file_length, sizeof(short int)) ;
num_read =fread(speech_samples, sizeof(short int), file_length, speech_file);
printf"num_read=%d",num_read;
  return 0;
 楼主| wansuiye 发表于 2012-4-13 12:12 | 显示全部楼层
没人知道吗。。。
五谷道场 发表于 2012-4-13 19:38 | 显示全部楼层
芯片是哪个型号啊,CCS是哪个版本?
