[PIC®/AVR®/dsPIC®产品] PIC16F877A单片机(如何写 配置字)
 楼主| aoyi 发表于 2022-10-10 15:38 | 显示全部楼层 |阅读模式
1 MPLAB X V5.0,编译器为XC8(V2.0)
单击production—set Configuration Bit----点击 generate source code to output ----复制生成内容到main函数
// PIC16F877A Configuration Bit Settings
// 'C' source line config statements
// CONFIG
#pragma config FOSC = EXTRC     // Oscillator Selection bits (RC oscillator)
#pragma config WDTE = ON        // Watchdog Timer Enable bit (WDT enabled)
#pragma config PWRTE = OFF      // Power-up Timer Enable bit (PWRT disabled)
#pragma config BOREN = ON       // Brown-out Reset Enable bit (BOR enabled)
#pragma config LVP = ON         // Low-Voltage (Single-Supply) In-Circuit Serial Programming Enable bit (RB3/PGM pin has PGM function; low-voltage programming enabled)
#pragma config CPD = OFF        // Data EEPROM Memory Code Protection bit (Data EEPROM code protection off)
#pragma config WRT = OFF        // Flash Program Memory Write Enable bits (Write protection off; all program memory may be written to by EECON control)
#pragma config CP = OFF         // Flash Program Memory Code Protection bit (Code protection off)
// #pragma config statements should precede project file includes.
// Use project enums instead of #define for ON and OFF.
#include <xc.h>
2 MPLAB V5.0,编译器为PICC
第一种方法:
// Config Register: CONFIG 配置字
__CONFIG(FOSC_HS&WDTE_OFF&LVP_OFF);//高斯速晶振,看门狗关闭,低压编程关闭
//__CONFIG(0x3f7A);  // 和上一条语句等价
/*   配置字的解释说明:
// HS oscillator 大于4M晶振
// XT oscillator 400K-4M晶振
// LP oscillator 小于400K晶振
// RC oscillator 阻容震荡,单片机不接晶振,外接电阻和电容来震荡,精度低,受温度影响大
// WDT enabled
#define WDTE_ON              0xFFFF
// WDT disabled
#define WDTE_OFF             0xFFFB
// RB3/PGM pin has PGM function; low-voltage programming enabled
#define LVP_ON               0xFFFF
// RB3 is digital I/O, HV on MCLR must be used for programming
#define LVP_OFF              0xFF7F
第二种方法:
上图中,配置字的值为3F7A,所以配置字也可以这样配置
__CONFIG(0x3f7A);
